Go to Post If your prototype works perfectly, you've been working on it too long. - Blair Frank [more]
Unread 11-11-2014, 18:26
yash101 yash101 is offline
AKA: null
cRIO UDP Communications Protocol
I am working on a small cross-platform driver station because of how annoying it is to keep switching between Linux and Windows. A lot of my programming happens in Linux and OS X, I have my favorite IDEs, I am a heavy user of the POSIX libraries, and my programs are designed for embedded Linux. Porting is easy, but it takes easily 5-10 minutes, especially because I need to create a new Visual Studio project.
I have not found a really good driver station for Linux so I am working on building one right now.
I am having a couple problems. I found this wiki page on GitHub by Innoying. It is basically a cheat sheet for the protocol. However, I am not understanding some stuff. There is one 64-bit checksum for the cRIO, and 4 32-bit checksums for the FPGA. However, if I understand correctly, this part of the protocol is from the driver station to the cRIO. If that is really the case, what are those values? The computers don't have a built-in cRIO. Is this a hard-coded value in the driver station?
I would love to have this up and running soon, so I can share it with you all. It'll not be legal for competition use, however!
Have fun and Happy Veteran's Day!
Unread 12-11-2014, 01:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: cRIO UDP Communications Protocol
This was a mechanism that allowed the field to ask the robot if its version matched the one sent. The value is simply relayed by the DS. It is not necessary for a DS implementation.
Keep in mind that the protocol is changing significantly for the roboRIO.
Unread 12-11-2014, 09:13
AKA: null
Thank you. I anticipated that it would change significantly, but it should at least help me a little bit until next season
