Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 01-11-2014, 07:04
Nate Laverdure's Avatar
FRC #2363
Re: Gearbox for mechanism or appendage
Cool project! Very cool that you'll be able to sell them.
It seems like whenever I talk about 3D printing at work (that's all the time), someone always suggests that I use printed parts to make my own metal castings. It seems easiest to do something like lost-ABS investment casting, taking advantage of ABS's low melting point.
Seems like this would be the perfect project to try this out. Where you have mating surfaces, you could add additional thickness and clean them up in a mill to get closer to the requisite surface finish.
Unread 01-11-2014, 23:51
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
These drives are very cool...I've been working to create a useful one for about three years.
I haven't released a unit for FRC because of the immense challenges.
I won't detail them here, but I will tell you that we have a "large" box of failed iterations.
I've attached a picture of a 400:1 unit with a 2.5" OD and an 8mm CIM input.
Here is a video....these are from May 2013.
http://youtu.be/tJoWlCDmaLg
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 02-11-2014, 15:37
AKA: Anthony Lapp
I'm in the sharing mood....table of previous design iterations. I've been working on these for a long time.
Anthony Lapp
RobotOpen
Unread 02-11-2014, 15:41
Oblarg Oblarg is offline
AKA: Eli Barnett
Very cool. If these ever came on the market, I'd definitely be interested. Way more compact than a planetary.
"The breakfast of champions!"
Unread 02-11-2014, 16:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I've been toying with the idea of a cycloidal gearbox for FRC manipulator applications for a while, but haven't had the time or resources to really get very far. It's exciting to see other people running with the idea, and that they have managed to get a lot further.
Unread 07-11-2014, 19:23
Andrew Duerner Andrew Duerner is offline
FRC #5818
Andrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud of
Sorry I haven't responded this past week, I decided to write a provisional patent for the gearbox in case there was something worth protecting. It took a lot more work than I thought to get it all written out. Interesting learning experience, I would recommend students interested in design to write a mock or real patent. With a provisional being only $65 to submit, it's really not very expensive.
I also got the website updated. You can find a little bit more info but the really important things aren't nailed down yet, max torque, weight, etc. Check it out at www.armabot.com.
That is an awesome video ajlapp. Such a small form factor for a 400:1. Are you going to keep working on it?
Unread 10-11-2014, 18:53
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Very cool stuff! I've been reading papers about these things and playing with designs for the past few days, I really want an excuse to build one.
Great looking gearbox. I'd love to hear more details on what kind of failures you ran into when going through different designs. I suspect that you need pretty tight tolerances on all of the parts so you land somewhere between "too tight to assemble" and "tore itself apart".
For the ABS approach, I like the idea of cheap printable parts that can be remade when they wear out. We've seen the need for high reduction/low load gearboxes in the past where something like this would work. If we don't need to replace it every few matches, then it might be worth it (entirely depends on what it's being used for).
Unread 10-11-2014, 20:50
President, VEX Robotics, Inc.
All,
You want to learn about the kings of the industry for this technology? Go to this site:
http://www.nabtescomotioncontrol.com/engineering.php
They absolutely dominate the industrial robotics market. FANUC, ABB, and Motoman all use this gearbox for their main arm joints. I have first hand knowledge that there are at least three of these bad boys (RC-E or RV-C depending upon the need) on each general purpose FANUC robots.
They have cool videos and detailed cross sections of these products.
Why would they do this? They have pretty much all of the patents on this stuff. Many of them are expired, but some of them are still very active.
Anyway, this is the place to go to learn about the best use of Cycloidal gearboxes.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 12-11-2014, 13:52
FRC #5818
Hi All,
I did some measurements and testing on the gearbox, particularly on the 168:1.
Weight came to 1.1lb (0.5 kg)
Backlash was 1.1 degrees
Efficiency was a bit trickier. I have a supply that has 3 different power settings and a very course amperage meter. I put a volt meter across the leads when I ran with a bare motor and then retested with the gearbox (no load). I did this with 2 different motor / gearboxes and in both directions. The voltage across with the gearbox was around 9, 12, and 14 volts, so I think the efficiency was hurt a little bit by spinning faster than what would be seen in normal operation. Without putting a ton of data down, the average of the results for efficiency under no load came out to be 61%. All but 2 of the results were +/- %7 from this.
I would expect that the values for the 264 and 552:1 should be very similar to the above.
Next up, making an adapter plate for a torque wrench to test max torque.
Andrew Duerner
Mechanical Engineer
Owner/Operator - www.armabot.com
Mentor FRC1717 2012-2013
Mentor FRC5818 2016
Armabot and FRC team involvement are unaffiliated.
Unread 11-06-2015, 05:02
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Originally Posted by Andrew Duerner View Post
Hi All,
Andrew:
If you could build in a FIRST standard bolt pattern, we could attach sprockets!
D
Unread 11-06-2015, 12:31
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
500:1 is probably a bit slow if the plan is to mate it to a CIM motor. At free speed, it would go down to 9 RPM or about 7 seconds per revolution. At peak power, it would be about 13 seconds per revolution. An arm sweeping 120 degrees would be between 2.5 and 4 seconds which would seem pretty slow.
The 125:1 & 250:1 arms have me pretty intrigued.
Are you measuring efficiency as "Actual speed / theoretical free speed"?
Richard Wallace and some others might be able to help you with a more accurate efficiency method that you could do.
A string and spool winch with a weight and stopwatch could probably be pretty effective way of measuring efficiency at several torque levels.
Unread 11-06-2015, 18:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Isaac is right, a string, weight, spool, and stop watch are the best method for this kind of measurement when speeds are low; e.g., when it takes several seconds for the weight to drop.
On the original topic, I recommend this lugnut remover as cheap example of cycloidal gearing. It was easy to find at Harbor Freight years ago. Don't know if you can find it there now. I posted some details and pictures a few years back, linked earlier in this thread.
Richard Wallace
since 2003
Unread 11-06-2015, 20:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Several of the four-arm-linkage lifts I saw this year only needed to span about 30 degrees of arc to pick up a game piece from the floor to quite a few feet off the floor, so 13 seconds per revolution would be a bit under 1 second. At these sorts of ratios, a CIM could compete for some jobs for which we would previously only have considered pneumatics.
