#361
Re: Registration 2015
My guess is that it would be 128 teams (2x last year), then they can use the same system 2x. Not sure how the elimination rounds would work, maybe a two team Einstein type of championship style, the winners of both fields play. |
#362
FYI, DC & Pittsburgh got updated sometime over the weekend with teams several teams officially off of the waitlist. I suspect other events have been updated as well.
#363
Hawaii and Las Vegas are now both showing open capacity of 5 and 4 respectively.
#364
They have been trying to do so for many years, and after tons of emails from our RD to raise it, they have finally listened. In the past, we kept having to have teams register on the waitlist and have FIRST switch them over to registered. Our event was capable of having 40+ teams but never could understand why FIRST put a limit of 27 up until now. -Glenn |
#365
can you provide a table or spreadsheet with those numbers please? and thanks
#366
Here's the spreadsheet for that day's tally.
#367
That was a useful spreadsheet also
but before I go do some excel work, do you have the table that made the graph, basically state, count example AK, 1 AL, 8 AR, 16 etc I want to update a spreadsheet I did about 5 years ago and look at the deltas. Thanks Ed |
#368
I neglected to name it anything meaningful. |
#369
I thought to check the tabs but got distracted and forgot. I downloaded the file and when I open the file it gives an error saying the file may have missing data. at first glance it seems to all be there,,,, I don't know if the file upstairs is broken or what.
Ed |
#370
Here are just the totals for the chart in CSV comma delimited form.
I had to give it an extension of .txt to upload it here. Also an .xlsx format for the whole thing to try. Last edited by Mark McLeod : 12-11-2014 at 21:14. |
#371
normalizing the data against state population, teams per million population
#372
Ed... this is eye-opening. Amazing numbers from Minnesota! Anyone from MN can share their perspectives on how they have managed to get FIRST into so many schools and communities?
#373
It looks like the 5 years gains, just some sample data points
2009 2014 Michigan 132 350 teams Minnesota 81 179 California 145 234 Georgia 28 61 New York 122 139 Texas 91 109 I remember in 2009 Michigan was almost desperate to get economic development done, and there was an aggressive push on all fronts.. I'm interested in seeing how this works out in a few years with economic development in that state. It would be nice to start building charts for each state with plot lines for the following ____teams / million population ____STEM undergraduate degree production ____gross state economic output There should be some interesting time delays between team startup and degree production. There should be some interesting way to normalize the economic data to make some sense. I'm working on building models for correlating FIRST with degree production and economic output. This data is key for creating policy support for FIRST. I need to go dig deeply in Michigan data on STEM degree production rates and technologist production rates. That could be golden information. Ed Last edited by ebarker : 12-11-2014 at 23:32. |
#374
There is a little bit of discussion there about how MN got to where it is. Let me know if you have any additional questions. Also to note: we have 600+ FLL teams and 107 FTC teams. |
#375
Here's the rate at which teams have been added to event lists (so far).
The big peaks are on mass opening, 2nd District opening, and 2nd Regional opening. Last edited by Mark McLeod : 14-11-2014 at 22:56. |
