Go to Post The best metrics are your own. Do you see the impact of your efforts in your community? Do you feel like you should/could have won Chairman's, but another team was even more deserving? That's how you know FIRST is really working. - dcarr [more]
Go Back   Chief Delphi > Technical > CAD
Unread 13-11-2014, 17:49
Zealii's Avatar
Zealii Zealii is offline
#QuadSquad
FRC #3494 (The Quadrangles)
Team Role: Student
Zealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond repute
Inventor CAD Library
After reading about how Solidworks releases a KOP for each season with common parts, I was wondering if there was a similar thing for Inventor. I have looked for a library with no luck. Sometimes there is a certain part on the manufacturers website but more often than not, the part that I am looking for doesn't have a CAD file. Is there a central location where I can download common parts that I would probably use during build season like motors, roborio, or gearboxes?
2014-Queen City Regional Finalists (868 & 3506)
2015-IndianaFIRST Kokomo District Finalists (5402 & 4982)
Unread 13-11-2014, 17:54
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Inventor CAD Library
Inventor releases the whole kit of parts every year.
The specific components you mention are almost always available on the manufacturer's website, usually in a universal STEP format.
Unread 13-11-2014, 19:35
Zealii's Avatar
#QuadSquad
Team Role: Student
Where is this KOP located?
Unread 13-11-2014, 19:37
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
http://www.autodesk.com/education/co...ended-software
Scroll down this page.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-11-2014, 07:00
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Here's the Inventor COTS parts library I've put together over the past few years. I've downloaded a variety of STEP files from AndyMark and Vex and converted them to .ipt / .asm files. It has a common set of gears and motors and such instead of every part having its own copy of a particular gear. It is not perfect (the fasteners are a bit of a mess for example), but there's good stuff in here.
http://www.nemoquiz.com/files/COTS.zip (300 MB)
Unread 14-11-2014, 07:35
Zealii's Avatar
#QuadSquad
Team Role: Student
Thank you so much!
Unread 19-11-2014, 13:17
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Zealli,
Let me know if you have everything you need.
As always Autodesk will be posting the field model and KOP for 2015 immediately after the Kick Off event on January 3, 2015.
Thanks to those who directed Zealli to Inventor KOP.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
