Re: VEXPro 3-CIM Ball Shifter encoder?
We are almost done building our practice chassis and we have included encoders for the first time. We ordered the Grayhill 63R series 256 encoders.
The 4 sample averaging is a great suggestion that we will implement. I presume this is just reading the encoder in teleopPeriodic() and keeping a running average of the last n samples. Can you elaborate on the 1x decoding or 4x decoding? |
In Labview, this happens in Begin.vi when you call the Encoder Open block. In C++ or Java, these are either parameters for the Encoder object constructor method, or have corresponding set methods to be called after instantiation. |
We are trying to source the wire and connector for the Grayhill 63r encoder (5pins) and the best/most appropriate way to connect this.
Anyone have an answer? |
Are the encoders in stock now?
