Go to Post FIRST should come with a warning label. - Tim Sharp [more]
Unread 14-11-2014, 21:46
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: FTC Zip ties sticking out
I've seen this issue many times with zip tie beater bar intakes for ball pickup. What i tell teams to do as as easy solution is to be able to have long zip ties but stay within the sizing limit is instead of putting them 360deg around the roller, just put them 180deg to each other (think 12 o clock and 6 o clock positions) and just make sure you have them vertical when you put the bot down on the mat before the match which would put them inside the chassis.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
