Go to Post Is it legal? Yes. Is it Graciously Professional? Yes. Is it smart? No. - dlavery [more]
Unread 14-11-2014, 22:20
Mdphilly Mdphilly is offline
FRC #5316
Mdphilly is an unknown quantity at this point
Out of control robot
We are having a problem with last year's robot and we are looking for some advice. When we turn on the robot and enable the driver's station, the robot acts crazy. Has this happened to anyone else or have you heard of this problem before?
Any help would be great!
Thanks.
Unread 14-11-2014, 22:46
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Re: Out of control robot
Define "Crazy". A few things that come to mind are:
1. Battery Voltage: A low battery can be the source of countless issues, causing random voltage drops, causing various electronics to brown-out
2. Joystick Input: Try running the robot with Joysticks disconnected, and see if that stills the beast. If so, then you probably need to calibrate your joysticks in windows.
Again, without knowing what you mean by "crazy" it can be a bit difficult to troubleshoot.
Unread 14-11-2014, 23:02
FRC #5316
Crazy means....the robot starts moving forward and backward without any movements on the joysticks.
Unread 14-11-2014, 23:17
A few items that might help:
#1: Are your speed controllers AND your joysticks calibrated?
#2: Are your joysticks set up with a deadzone?
#3: Are you SURE that you're sure that you're not in autonomous on startup?
#4: Has the code changed at all since the last time you ran the robot, and was the robot working OK at that time? (This is to eliminate the programming team's coding as the problem, BTW--still doesn't let 'em off the hook for their setup. )
A few other "standard" diagnostic questions: What are the lights doing (RSL, cRIO, power board, D-link)? What messages are cropping up on the driver's station? What mode is the D-link set to?
And, one more question: Does it do the exact same thing when you set it on blocks and power it on and enable it?
Unread 15-11-2014, 00:27
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Could it be running in autonomous mode instead of teleop?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-11-2014, 20:54
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
We had this issue earlier this year and it was due to a faulty battery. Check your voltage right before you enable, or if you have a battery beak see what the status of your battery is.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 19-11-2014, 02:09
lakecat's Avatar
lakecat lakecat is offline
Cat Expert
AKA: Tristan Thompson
FRC #2635 (Lake Monsters)
lakecat is an unknown quantity at this point
Calibration comes to my mind. I remember when the PID loop on our robot wasn't calibrated and just as much as tapping the joysticks caused the robot to shoot off.
Unread 23-11-2014, 08:27
DonRotolo's Avatar
Back to humble
FRC #0832
Disconnect the PWM inputs from the motor controllers: If it still moves, the controllers are faulty (possibly wired incorrectly).
If it doesn't move, then plug in controllers (robot off!) one at a time to find the problem. Then look in the code for that/those motor PWM outputs.
