Go to Post I wanted my team to be rewarded for something they do, not because they do it for the award. - MikePres [more]
Unread 15-11-2014, 10:22
NRLeuenb's Avatar
NRLeuenb NRLeuenb is offline
AKA: Natalie
FTC #10794 (The Spaceballs)
NRLeuenb is an unknown quantity at this point
Beta Testers: Permissions on the RoboRio
Beta Test Teams:
Is it possible to view/read anything in the /dev/ folder once you ssh to the robot? Or do you have to be a specific user? We don't want to write, just read. And are we prevented from running processes external to the main robot process?
Unread 15-11-2014, 11:59
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Beta Testers: Permissions on the RoboRio
Originally Posted by NRLeuenb View Post
Beta Test Teams:
You have full access to the filesystem through ssh. The user created by NI is "admin" which has admin access to the file system
The admin user has full read/write to the dev directory. You can also make your own users as well.
First and NI do not lock down the file system at all.
You can also execute your own processes, and terminate any processes you wish - obviously that comes with the cautionary of things to ensure u dont terminate or block the robot code.
The only folder which I believe admin cant write too is the /proc folder, but I will have to check that later
Again this has been our experience with the Beta hardware, and FIRST has the right to make changes for the actual production hardware, but I doubt FIRST or NI will change this in the production system because its so close to kick off, so its a good bet that the released version will also have full root access to the filesystem.
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 15-11-2014, 12:56
You shouldn't be able to write to /proc... That's a proc file system. There might be a couple files there which are writable, but in general, it should be read only.
As far as I have been able to tell, admin is root, which means that you have free reign over the box.
We are running our robot code as a set of ~10 processes communicating over shared memory IPC on the roboRIO. Works flawlessly.
Unread 15-11-2014, 13:33
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
On a side note, what init system does it run?
Unread 15-11-2014, 13:55
NRLeuenb's Avatar
AKA: Natalie
Thanks to all who responded, that was very helpful!
Unread 16-11-2014, 13:59
Controls Engineer
AKA: Kevin
Systemd, I believe that answers your question, correct?
Regards,
Kevin
Unread 16-11-2014, 15:01
x86_4819's Avatar
computer-whisperer
Regards,
Kevin
Yes, it does. Thanks!
