Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 15-11-2014, 15:30
Re: pic: Lightweight 8 CIM Shifting Swerve Drive Chassis
Originally Posted by Bryce2471 View Post
With good code, a rectangular robot, and 6 CIMs of torque; I think you would be able to do any swerve movement with a little scrubbing.
What makes you think that?
Unread 15-11-2014, 17:13
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Each wheel is independently steered, and if you had a 6 CIM 4WD tank that was 21" by 35", it would be able to turn in place without too much trouble.
This drive would be able to turn in place or translate without any scrubbing. It wouldn't have any resistance until it turned while driving. I think this relatively small disadvantage would be outweighed by the advantage in a pushing and driving straight.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 15-11-2014, 23:23
It sounds like you just moved the goalposts. But perhaps I am misunderstanding. Are you still saying that it "would be able to do any swerve movement with a little scrubbing" ?
Unread 15-11-2014, 23:35
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yes my intent was to support that claim. The only time scrubbing would be involved is when translating arbitrarily, and rorating at the same time. I believe that in that case, the 6 CIMs would be able to power though the scrubbing, given the gear ratio and width/length of the drive base.
Obviously, this is an opinion, and you can be sure without testing.
Unread 16-11-2014, 00:00
Yes my intent was to support that claim. The only time scrubbing would be involved is when translating arbitrarily, and rorating at the same time. I believe that in that case, the 6 CIMs would be able to power though the scrubbing, given the gear ratio and width/length of the drive base..
What wheel angles and wheel speeds would you use to make that bot pivot around, say, the front left wheel? (a common swerve maneuver).
Unread 16-11-2014, 00:34
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I would not call this a "common swerve maneuver" as I have only ever seen one robot get notable benefit from using it. Turning around one wheel is the worst case scenario for a swerve with front and back wheels tied because two wheels on the same side should ideally have a large speed differential.
Regardless, It should be possible to perform this maneuver with something like this:
https://scontent-a-sea.xx.fbcdn.net/...2a&oe=54DF1511
(and a lot of scrubbing)
Unread 01-12-2014, 11:50
Rotating around a point other than the Center of Geometry of the robot is a very basic swerve maneuver.
Indeed. I choose the front left wheel as the Center of Rotation to simplify the problem statement, and to pick an extreme case to try to clarify what you meant by "do any swerve movement".
https://scontent-a-sea.xx.fbcdn.net/...2a&oe=54DF1511 (and a lot of scrubbing)
If you are interested in exploring the physics of "scrubbing swerve", I invite you to participate (or just read along) here.
