Go to Post Education doesn't have anything to do with how much money a person can make. Experience, Perseverence, and Character do. - Jnadke [more]
Unread 13-11-2014, 23:59
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Lightweight (relatively) 2 CIM Shifting Swerve Drive
Unread 14-11-2014, 00:00
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Re: pic: Lightweight (relatively) 2 CIM Shifting Swerve Drive
How did you do the serpentine calculations? Gates IQ?
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 14-11-2014, 01:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks good. Why do you have two encoders? Is one for rotation?
Is the shifting shaft custom or vex?
What pitch is the belt?
Also, out of curiosity: is the gear running on a bearing or is it just bolted to the wheel? I designed mine with a bearing in the gear for safety, but is it necessary?
Is the wheel running on bearings or just on an aluminum hollow axle?
Unread 14-11-2014, 02:20
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
No, I just did an approximation with the center of the belt backing. It does't need to be perfect. If the belt length was off by up to a half inch in either direction the tensioner would adjust.
Yes, one measures wheel orientation, and the other measures travel speed.
It's vex, but it's shortened on both ends.
HTD 5mm
I doubt that a bearing in the gear is necessary. With a dead axle that's well
supported, bearings on either side of the wheel, and a gear that's close to the wheel, you shouldn't have any trouble just bolting the gear to the wheel.
The drive wheel is running on two ball bearings on an aluminum hallow axle.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 14-11-2014, 03:16
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Can you put one bearing in the gear and one in the opposite side of the wheel? You still get the support that way, as well as alignment. And you still only use two bearings.
Unread 14-11-2014, 07:57
Nice Job!
Unread 14-11-2014, 12:28
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
really amazing. Now all you need is to be allowed eight CIMS on the bot. and a refrigerated main breaker.
Unread 14-11-2014, 13:51
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
you could do that, although it's not the optimal solution in my mind because the bolts would be loaded in shear by the weight of the robot.
Nice Job!
Thank you!
this accually only uses 1 CIM and 1 mini CIM. The breaker would most likely be okay, assuming that auto-shifting code was used.
Unread 14-11-2014, 22:04
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thank you!
Good to consider.
What miter gears are in there? Are they the vex ones?
And I assume those pulleys are aluminum... just a random thought.
Unread 14-11-2014, 23:26
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Good to consider.
They are 20 tooth 20 pitch steel gears from SDP/SI.
Yes they are aluminum pulleys from B&B man.
Unread 15-11-2014, 00:04
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Ok, good. It just seemed like they would be heavy for this design due to their solidity.
Unread 15-11-2014, 16:43
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
What are you referring to as being solid? Are you talking about the aluminum pulleys or the steel miter gears?
Also, what roller bearing did you use as an idler? I just put a solid steel stand-in to fill the space.
Unread 15-11-2014, 22:12
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The pulley is solid aluminum, unlightened. The miter gears I would highly recommend against shorening the hub (widening the bore it fine) due to the strange geometry making it hard to machine.
For the bearing, I used these:
http://www.bocabearings.com/bearing-...2-SR1634ZZ3PS2
Unread 16-11-2014, 01:09
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks for the resource! I've never used them.
Although, I was wondering about the bearing that you used to tension the lower belt, not the 0.75" bearing for the shifter. lol
Unread 16-11-2014, 05:00
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Oh. For the lower belt, I just used a steel sleeve around a slightly longer aluminum sleeve. The aluminum sleeve had a 10-32 screw go through and clamp to the top plate. Then the steel sleeve was still free spinning, but constrained in place.
You could just use a 1/4" or 5/16" aluminum sleeve and use a 1/4" or 5/16" bearing from McMaster or Boca Bearings. I know 192 used Boca last year for their gearbox gears, but personally I haven't used them.
