Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 17-11-2014, 08:06
Al Skierkiewicz Al Skierkiewicz is online now
Rosetta & Philae
I am surprised that no one has started something on this achievement so here goes.
I think that this is one of the most important achievements of recent history. Humans have landed a spacecraft on a foreign body traveling through the solar system at astonishing speed and with such a small gravitational field it produced the kind of problems we find every year in our games.
Reading this morning, the gravitational field of a 4 kM object makes the lander's 200 lb weight equivalent to about 1/30 of an ounce. This required the lander to screw itself into the surface of the comet to hold on. The comet is currently traveling about 23 miles/sec and is 315 million miles from earth. Imagine that! A ship traveling for more than ten years, catches up with an object traveling at 88,00 miles per hour, over 300 milllion miles from Earth and then was able to land on that moving object. Add to that, an unknown surface, temperatures of -70 on the surface and gas escaping constantly in the solar wind.
I can't think of anything but "cool"!
Unread 17-11-2014, 09:14
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: Rosetta & Philae
It's truly inspiring. Also, NASA's first Orion test flight is within a couple weeks! If this flight also goes well, they will use this crew module in future flights to land more people on the moon, asteroids, and even mars.
We're living in a freaking awesome time.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 17-11-2014, 09:24
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
You can relive the excitement here (through Randal's eyes)
Disclaimer: Expect to lose an hour of your life to this.
Hi!
Unread 17-11-2014, 09:45
Not to diminish the magnitude of the accomplishment in any way, but Mars is traveling through the solar system far faster than that comet1.
The accomplish is novel and impressive because of a host of other factors, including but not limited to its size, gravity, terrain, rotation period, and orbit.
1at the time of landing
Unread 17-11-2014, 09:57
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The accomplish is novel and impressive because of a host of other factors, including but not limited to its size, terrain, and orbit.
Not to mention the chained gravity assists!
Earth to solar orbit, earth assist, mars assist, earth assist, asteroid flyby earth assist again, another asteroid flyby, then rendezvous with the comet. Planning a trajectory with 4 assists, 2 flybys, and final orbit in mind over a 12 year period is a very easy thing to screw up
Unread 17-11-2014, 10:22
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
They had this thing sit silent for 10 years! Then they used gravity to sling them around, then they did some zig zags to slow down, then they landed a little pod on the comet and drilled into it!
I don't even know I am going to eat later on today and these guys planned most of this 10 years ago!
Unread 17-11-2014, 10:23
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Except unfortunately it didn't. From what I've heard, the 'harpoons' failed to fire and anchor Philae into the ground, causing it to bounce back up into space twice, at one point an entire kilometer above the surface of the comet, which took two hours. Luckily, 67P's gravity pulled it back down, but the new landing site was hundreds of meters away from the planned site. Scientists still haven't located its final resting position, but based on photos from the probe, they believe it ended up landing next to a cliff, and leaning askew on a rock. This caused its solar panels to get much less solar power than planned, and as a result the battery died, bringing the probe into sleep mode.
However, this is still a huge accomplishment, and according to BBC, "the probe managed to complete more than 80% of its planned primary science campaign on the surface", including drilling into the comet's surface, and was able to send its data back to Earth before losing contact. Scientists are hoping that as the comet approaches the sun (which sounds like next August), Philae will get enough light to reboot and charge its battery again.
Unread 17-11-2014, 10:41
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
https://www.youtube.com/watch?v=H08tGjXNHO4
I saw the above a few days before the landing. Well worth the watch. (As a mentor, there are days I feel like the Male character)
And Philae may reawaken. We'll have to wait til next August but if it does, be curious to see what happens then. Maybe it'll get enough sunlight to keep it charged for a more prolonged period of observation.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 17-11-2014, 11:24
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Dave Lavery keeps tweeting some really interesting things about the mission.
Unread 17-11-2014, 11:25
Philae is currently in a coma.
Maybe it will wake up by the time Chury-Gera gets a coma of its own.
Unread 17-11-2014, 11:39
pyroslev's Avatar
VirginiaFIRST FTA
+2 and FTW.
Unread 17-11-2014, 11:41
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I'm just concerned as to what the ejected gases will do to the lander once it reaches that stage...
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 17-11-2014, 12:04
Voyager 1, Galileo, MESSENGER, and Cassini all used multiple gravity assists.
Unread 17-11-2014, 17:01
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Hopefully, the solar panels will be able to get sunlight before the electronics freeze. Once that happens, it's likely game over. I don't know the battery life in sleep mode, nor what temperature minimum the electronics can withstand. Has anyone found this information? I know without heaters, current flight hardware lasts only minutes.
On the plus side, useful science data was acquired from Philae and this will give us new insight into comets.
Oh yes, and ESA gets the award for the coolest video associated with the Rosetta mission.
Unread 17-11-2014, 17:15
Best Available Data
FRC #1778 (Chill Out!)
I actually think it's pretty amazing we don't screw it up more often. How often do we lose a space probe because we commanded it into the wrong orbit? It seems like if we can get 'em into space successfully they usually make it to their final destination. The interplanetary FedEx drivers of the world do a great job getting their packages to the intended destination.
We looked this up at work because we were curious what the most ridiculous trajectory is, and it looks like MESSENGER wins.
How do we know we live in the future? Two people looked at each other and seriously asked, "Did our robot just bounce off that comet?" Maybe one day bounced comet landings will be as routine as bounced airplane landings.
One space robot taking pictures of another space robot
