Re: Out of control robot
We had this issue earlier this year and it was due to a faulty battery. Check your voltage right before you enable, or if you have a battery beak see what the status of your battery is.
Calibration comes to my mind. I remember when the PID loop on our robot wasn't calibrated and just as much as tapping the joysticks caused the robot to shoot off.
Disconnect the PWM inputs from the motor controllers: If it still moves, the controllers are faulty (possibly wired incorrectly).
If it doesn't move, then plug in controllers (robot off!) one at a time to find the problem. Then look in the code for that/those motor PWM outputs. |
