Go to Post FIRST Isn't just about the robots, it's about Gracious Professionalism, co-opetition, and outreach also. - Julia Magoolia [more]
Unread 18-11-2014, 19:32
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Robot Spins on Start
Always double check your wiring, and then have another person double check just to be sure. Mistakes happen, and many teams have had the same thing happen (our team is no exception). If you correct the problem and they still work, then use them until they finally do die. I would highly recommend NOT using them in a competition environment again, as they will most likely fail unexpectedly, often at the worst time.
I'm right 90% of the time, so why worry about the other 3%?
