Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 18-11-2014, 11:22
W_Yingst W_Yingst is offline
FRC #4553
W_Yingst is an unknown quantity at this point
Need to invert Joystick axis output
Our team is moving into Java for the first time this year, and we are creating our "Hello World" program (Simple driving). We are using the arcadeDrive method of a RobotDrive class object. It will drive forwards and backwards in the way we want, but the turning is inverted. Left joystick results in a right turn, and right joystick in a left. Inverting motors does not solve this problem, so I think we need to invert the x axis output from the joystick. Has anyone had this problem before? Any help inverting these values? Thanks.
Unread 18-11-2014, 11:24
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Need to invert Joystick axis output
All you need to do is place a "-" in front of the value coming out of the joystick going into the ardaceDrive() call. This will invert the value so -1 would become 1 and 1 would become -1. Something like this:
robotDrive.arcadeDrive(joystick.getY(), -joystick.getX());
Unread 18-11-2014, 11:46
dash121 dash121 is offline
FRC #4085
dash121 is an unknown quantity at this point
Have you thought about looking in the driverstation and switching your joystick ports under the setup tab switching the joystick imports. Your java code calls for a joystick in port one or port two. Your computer doesn't have a USB port one or port two.. Thats where the FRC driverstation comes in.. to define what is port one and port two. You just need to switch the joystick ports. This method works better versus putting inverse in front of your code.
Unread 18-11-2014, 11:50
Flywheel Police
This would make sense if their robot was set up for tank style steering not arcade. I believe what is meant is that when the joystick is pushed left the robot is turning right and vise versa. I read this as there is only one joystick present.
Unread 19-11-2014, 10:34
FRC #4553
Yes, we only have one joystick. Everything works except we need to invert x. With the code notmattlythgoe showed, don't you normally use a normal joystick object? as in define the object and then just call it in? I haven't seen Joystick.getx and Joystick.gety before
Unread 19-11-2014, 10:41
FRC #4553
notmattlythgoe, thanks so much that method worked perfectly. Problem solved.
Unread 19-11-2014, 11:17
If you have some spare time, you might want to examine your wiring and your code to figure out why you had to do this. It could be an educational experience.
Unread 19-11-2014, 11:27
Flywheel Police
I agree with Ether, this isn't something you normally have to do, so it could be an indication that something is backwards somewhere.
