Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Unread 20-11-2014, 08:05
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Swerve VI based on the 2011 paper & excel by Ether
Are you still having this issue with your code, after making the sequencing changes that other posters have recommended?
If so, here are the intermediate values you should be getting. This may help you track down where the error is
Thank you for the numbers I was able to see the error was in the gyro correction of the joystick inputs. The gyro angle input is supposed to be in radians. I looked at the WPI holonomic VI and realized this. The sequencing changes (going to all wires) didn't change any output values which is why I was confused.
Also do formula nodes execute faster than the equivalent code on the block diagram?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
