Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 20-11-2014, 09:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: GBX-114 swerve with PTO
Unread 20-11-2014, 09:26
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
Re: pic: GBX-114 swerve with PTO
Why did you choose those gear ratios? Most swerve is ~ 10fps and your low gear is 12fps. I haven't done the math, but based on our experience, you'll have problems accelerating in high gear. A 5-8 fps low and 10-15 fps high would be better IMO. Also, what's the sprocket at the top of the wheel module for?
Unread 20-11-2014, 10:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
This is a 4-cim, 4-minicim drive.
This year, we ran a free speed of around 17fps with 4 cims only and had no problems accelerating at all. 1678's 6-cim drive was geared for around 22fps. This is an even more powerful drive, so I bumped it up to 24fps. The math works out; for anything more than a couple feet it is easy to use high gear (with < 0.05s of lag behind low gear).
The sprocket is the output of the PTO. It is not mounted to the module, but shifts on the shifting shaft.
Unread 20-11-2014, 11:23
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Have you done the calculations to estimate current draw on this? 1678 had to take extra steps to reduce the chance of popping their main breaker. Same goes with 254 and many other teams. The only reason 6-CIM drivetrains are even possible is because we know the breaker can hold more than 40A for longer than the spec sheet says.
You're adding 230W of power AND reducing torque. It's not a matter of acceleration, it's a matter of keeping your robot powered while you accelerate.
Unread 20-11-2014, 11:25
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
Looks sweet, but I am concerned about the turning gears, they're so close to the ground that if anything bounced up, it could potentially break or chip a gear tooth.
Alumni from 75 and 1885
Unread 20-11-2014, 11:47
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I don't think the math will work out on those speeds when you take into account the voltage drop that happens when you run all twelve motors on at the same time.
Unread 20-11-2014, 19:45
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
The current drop from the turning motors is a significant factor here, I think.
I would be very surprised if a swerve like this didn't blow the main breaker in a pushing match, even in low gear. IIRC FRC 2451 had current-related problems pushing an immovable object (read = our robot) last year with just 4 CIMS at a lower speed.
Unread 20-11-2014, 20:40
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
This will blow the breaker in a pushing match due to the massive power behind it. However, as with any high-geared 6+ cim drive, there must be good autoshifting code to prevent disasters. IIRC 1678 had a main breaker blow in the finals at SVR due to their autoshifting code having problems.
With swerve drives, if we get into a pushing match, we have three
options:
1. Translate away. Good for offensive tactics, especially with this blistering speed.
2. Push back. Useful only against lightweight robots or if we are stuck somehow. Or to slow other's robots down.
3. Cross the wheels. If the wheels are in an X-formation, then we can't be pushed unless they lift us (cue opponent's breaker blowing). Esentially, the driver has a trigger to lock the wheels, and when the opponent tries to go another direction our driver releases the trigger and moves. This is an extremely effective defense (in theory) as long as our driver can move to block them when they try to get past. I'm confident our speed is high enough for this.
The purpose of low gear is to allow for precise positioning and very short drives. That's why it's geared so high here.
The 40a breakers are on each motor. The main breaker is 120a, which is usually the problem.
Thank you for the input. I hadn't considered that. However, this only supports slightly more power than 6 cims, so it might not be that bad.
There is around 0.25" clearance to the ground. Not much we can do about that, but at least they're vex gears so they're easy to replace. Many swerve drives use gears so close to the ground, and I haven't heard of so many problems.
EDIT: One of our mentors mentioned that a bigger problem would be the current spike killing us on startup. Some things we have to solve with software; this kind of drive won't be used for at least a year (2016 game) so we have plenty of time to do tests.
Unread 20-11-2014, 21:19
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
options:
How did you come to the conclusion that you can't be moved when the wheels are in an X?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 20-11-2014, 23:42
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
In order to move the robot, the pushing robot would be acting against the traction wheels. Any direction that they are pushing from they would need to scrub the tires.
You could turn the wheels 90* from their push too.
Unread 21-11-2014, 00:05
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
D'oh. The low gear is actually 9.8fps in the photo. I accidentally marked it down as 36 tooth instead of 44 tooth in the calculator.
Then the robot is definitely traction limited. It draws 240 amps at maximum (lifting) torque. I was worried about increasing the pulley to get the free speed under 12fps, but it turns out that won't be an issue.
So the speeds are 24.0fps/9.8fps.
Unread 21-11-2014, 01:19
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Assuming your contact patch is square an X with 45° wheels is the most effective (I know that a 1" wide, 4" dia wheel with Blue Nitrile is approximately square) because you are applying force along the longest line you can draw in that shape. If you measure your contact patch and find it is a rectangle you can calculate the most effective angle to put your wheels at when you make this maneuver. (Not sure how much difference that would make tho...)
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 21-11-2014, 01:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
It would increase contact area, but I want to be able to lock the wheels without having to spend power on the motors. I guess putting them in brake mode would do the trick.
Unread 21-11-2014, 02:16
Lead Bumper Mentor
AKA: Mike Marandola
Since the contact area and amount of force would be the same regardless of the wheel angle, there might not be any difference. This is not taking the tread pattern into consideration though. Which is why the X formation might be beneficial. I think the X pattern will both reduce the wheel's ability to rotate when pushed and utilize the effects of the tread "fingers".
The contact area would remain the same.
Nathan, I know you said that 365 did testing on diagonal vs. normal tread. Did you guys happen to test the tread sliding sideways as well?
Unread 21-11-2014, 02:41
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Oh wait, you're right. I was thinking of another tread with diagonal tread in it...
Regardless, it shouldn't matter. An x-configuration would allow the motors to just sit in brake mode I think.
