Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 22-11-2014, 06:04
matan129 matan129 is offline
FRC #4757 (Talos)
Rookie Year: 2015
matan129 is an unknown quantity at this point
Power Distrobution Panel + Jetson TK1
Hey,
My team has acquired a Jetson TK1 for this year. I was wondering if there's any convenient way to power it from the Power Dist. Panel?
Thanks,
Matan
Unread 22-11-2014, 11:43
Re: Power Distrobution Panel + Jetson TK1
The TK1 runs on 12 volts (and can work down to 9.6 volts). A straightforward connection from a normal pair of Wago connections on the PDP through an appropriately-sized barrel connector seems to me like it would be fine.
Unread 22-11-2014, 16:01
yash101 yash101 is offline
AKA: null
Wouldn't it be a really good idea to add a buck-boost convertor before it? This way, those pesky voltage spikes and drops won't do anything to it. The voltage in batteries can easily dip below 9.6v during competitive maneuvers! It's just about timing when all the motors turn on on the robot at the same time .
Unread 22-11-2014, 16:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
If it draws less than 2 amps 1.5 amps, you can run it through the Voltage Regulator Module.
Unread 22-11-2014, 17:03
Originally Posted by cgmv123 View Post
If it draws less than 2 amps, you can run it through the Voltage Regulator Module.
Less than or equal to 1.5a
Let's not destroy any VRM's here.
Unread 22-11-2014, 17:24
AKA: null
If you are talking about the convertor used by the bridge, note that it runs at 5v. The voltage required by the Jetson (min) is 9.6v!
Unread 22-11-2014, 17:39
cgmv123's Avatar
AKA: Max Vrany
Noted.
There's a 5V rail and a 12V rail.
