Go to Post "Dress to impress," typically, means no denim (sorry, Dean)... - Madison [more]
Unread 22-11-2014, 17:39
iggy_gim's Avatar
iggy_gim iggy_gim is offline
AKA: Theodore Kim
FRC #5123 (Mechadogs)
iggy_gim is on a distinguished road
Virtual Reality 1st Person Driver?
Has anyone ever thought of hooking something like an oculus rift/google cardboard to an onboard camera for the robot to create a sort of 1st person driver for the robot. You can argument the vision to aid in aiming, driving, etc. I know in some aspects it might be cumbersome, but I think it sounds like a good idea. (Is it even allowed in FRC?)
My motto: Eh... that looks about right...
2013: Team 2344 Saunders Droid Factory
2014-16: Team 5123 Mechadogs, Captain/Founder
2017: Team 5123 Mechadogs Mentor
Unread 22-11-2014, 22:14
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Virtual Reality 1st Person Driver?
Sure it would be allowed. (and I have spent hours thinking about this)
The problem lies with the infrastructure of FRC itself. There is a bandwidth cap for robot-driverstation communication, and to get 3d you would need 2 cameras streaming to the DS to work. The problem arises with the fact that you have to choose (Pick any two)
  • Horrible Resolution
  • Horrible Framerate
  • Horrible Compression
I, personally, would get a pretty severe headache from that for even just a few minutes.
Were we able to send dual 480/720p 20+fps cameras, it would be definitely a viable control system IMO.
Unread 23-11-2014, 00:03
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Originally Posted by BBray_T1296 View Post
.. and to get 3d you would need 2 cameras streaming to the DS to work.
Combine the 2 images into a steroscopic image on the robot then send frames of that steroscopic image. So the viewer at the driver's station can wear either the old fashioned red/blue or polarized lenses. Should be able to do it well within the computing power offered by a laptop that fits within the COTS rules if those do not change this year.
http://www.3dglassesonline.com/learn...d-glasses-work
Which oddly enough in my previous suggestions I suggested sending full frames one at a time (aka key frames) instead of a stream of video changes. It should be less difficult to make the network handle that sort of work. If you snap the pictures from the 2 cameras, the proper distance appart, process them, then send that (as quickly as you can) that will likely work out. Even if you get a single static image it would still exhibit depth.
Unread 23-11-2014, 00:36
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Remember that headsets need to be disconnected from the driver when the match starts, and if cable get tangled or something you will lose precious seconds.
Unread 23-11-2014, 00:58
techhelpbb's Avatar
If the glasses are merely standard polarized or red/blue lenses you wouldn't have any cables to tangle. Another upside.
Extra amusement points though if someone gets some displays and retrofits a ViewMaster .
Unread 23-11-2014, 01:04
I am Dave! Yognaut
AKA: Brian Bray
Which oddly enough in my previous suggestions I suggested sending full frames one at a time (aka key frames) instead of a stream of video changes. It should be less difficult to make the network handle that sort of work. If you snap the pictures from the 2 cameras, the proper distance appart, process them, then send that...as quickly as you can that will likely work out. Even if you get a single static image it would still exhibit depth.
Now that is an interesting idea. Get a smallish polarized 3d tv and wear those glasses you get from the RealD 3d movies.
I think the OP was talking about integrating the gyroscopic capabilities of the Oculus to control the robot by steering the robot and raising/lowering a manipulating arm, which would independantly be possible (Via a TrackIR set or similar)
Unread 23-11-2014, 02:17
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Oh. That's a really cool idea! Would it still look okay through those glasses?
Also, as an alternative to using just tilt sensors in the Rift, you could use Kinect for the arms.
Unread 23-11-2014, 07:38
techhelpbb's Avatar
Using colored lens you loose some color. For any really important colors one could probably find the best colors for the lens set and simply swap the real colors for that color during the processing. Upside to this is there is nothing unusual about the display. You could just use the existing laptop displays.
Using polarized lens you get much better color reproduction at the cost of a compatible display.
Unread 23-11-2014, 08:20
This form of interface is normally used when you are miles way from the real device/environment and needing to immerse yourself into the situation as if you could be there. This is true whether it is a visualization cave, 3D glasses, etc.
When you have a view of the situation, I think a HUD or secondary monitor is a far better approach. This allows pilots to "see" what radar sees, but doesn't generally remove and try to reproduce the things that are in front of the craft.
If you have a rift, I'd encourage you to experiment with it using any of the simulators available. Identify beneficial experiments and then try them on the robot. I highly doubt that the driver would benefit from wearing these, but perhaps the operator trying to manipulate the arms/rollers/etc would.
If you don't have a rift and are looking to justify the team buying one, I'd encourage you to write up the details of how it would be used.
Greg McKaskle
Unread 23-11-2014, 10:28
yash101 yash101 is offline
AKA: null
Last year, on my vision system which I didn't finish, I had the goal to have some driver interface where the image is converted to a vector, only with keypoints. This way, you get a lot of information to your face, but it doesn't look that bad. You can also run this at a higher rate without exceeding bandwidth restrictions.
One practical idea that I thought of is a...HUD!
You are getting the video feed directly from the glasses, not the robot. This way, you can see around and not get nauseated by the intense motion blur on the robot. You have a coprocessor on the robot, calculating things such as distance to objects, or maybe even robot position on a minimap. This can be displayed at the corner of the display and the driver merely has to move his or her eyes to get the measurement.
Unread 23-11-2014, 11:53
iggy_gim's Avatar
AKA: Theodore Kim
Yes that is what I was getting at. However, I was not thinking to control steering via the glasses because that would be impractical for 360 degree turn (you would have to turn all the way around). Although now that I think of it, it would be interesting to control steering via the glasses, that's something that i would have to think about.
See that is where I wanted to take the next step of this system to, an interactive arm control system. But what about it you build gloves and put some sort of button sensor/switch in the arm of the robot so that when the robot successfully grabs an object a small micro-vibration motor in the gloves turns on as an added user response (just an idea...)
No need to make a who rift apparatus for that, you need something like this:
http://www.instructables.com/id/DIY-...A-the-Beady-i/
Thats also an idea, but not as fun as a 1st person display.
That is the only problem that i saw with this idea. That will take some thinking! If anyone else has any ideas I would love to continue this conversation.
Unread 24-11-2014, 08:14
ColinHalter ColinHalter is offline
Assassin
FRC #0811
Team Role: Animator
ColinHalter is an unknown quantity at this point
Technology issues aside, I think that having a first person view of the bot would be a huge disadvantage. When you're driving the robot, you're able to see the whole field and what's going on, where (e.g. Map Awareness). With a first person view, you are limited to a small window of visibility. This may help with aiming, but this is a team game* and its important to know what's going on behind you.
*Going off of A.A.
Unread 24-11-2014, 08:22
g_sawchuk's Avatar
g_sawchuk g_sawchuk is online now
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
In the future, virtual reality could be used to make a driver SIM which would be just as adequate for driver training as driving a normal robot if it was done properly. It could be difficult to make though.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 24-11-2014, 08:33
techhelpbb's Avatar
Years ago I worked out a 'virtual reality' simulation of a FIRST robot in VRML.
LOL some of you probably were not alive then.
It had really poor physics modeling and I suspect that most modern game engines would put it to shame.
Considering it was for fun I wasn't really putting much into it.
That said a modern game engine and Oculus Rift for immersion should be possible.
Considering what one can do with mere shutter glasses.
I am pretty sure DarkBASIC has Rift integration and real time accelerated physics support.
LOL I've had a DarkBASIC license since VB6 I bet that's older than some of you as well
Unread 24-11-2014, 09:37
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
We had a HUD last year, with a screen on the glasses. It was pretty sweet, but when the camera's image was up it wasn't nearly as useful as you'd think. We won the Innovation in Controls award on Galileo since the Rockwell people were so impressed by the solution we used to comply with the rules and still not lose much time at the beginning of the match. This year we won't use the same setup since the drivers do not want the cumbersome-ness of it - yet they still want some of the info the HUD gave them. We're working it from a different angle for this coming year.
A whitepaper for 2014's HUD should be up sometime after Thanksgiving Day.
