| Thread Tools |
Rating:
Display Modes |
#16
Re: One tool/machine to level up a moderate shop
There are ways of getting around these issues. You can buy spacers and shaft collars.
#17
Lathes have other uses however. Centering holes in round stock to quickly make standoffs is a big one. You can also tap holes with a lathe, and I have even known some teams to use it to broach. IMO it is also much quicker to learn how to correctly use a lathe than it is a mill, an important thing to consider when you have high school students using machines. |
#18
A decent quality, used lathe will unlock much more potential than any other tool at the same price range.
#19
I would recommend the Rage 3 saw that someone else mentioned. It's going to do a faster job with nearly equal cut quality and save you a bunch of money. |
#20
An alternative is an X-Y milling vise for your drill press. You can do light milling with somewhat more flexibility than the lathe setup. Avoid the very cheap ones, they are terribly inaccurate. These are great for drilling accurate hole patterns as well (and often that's the only use they see). Fair warning: Even if your drill press is a huge industrial beefy monster, this WILL hurt the spindle bearings a little each time you use it, but perhaps this trade-off is acceptable. New bearings are not costly, and the repair is good for the kids to learn. But a drill press is not designed for side loading on the chuck, just know that. Give yourself some time to find a good machine, maybe a whole year. Find a parent or local business willing to show you the basics (or the trade school option mentioned above). Buy the book "How to run a Lathe" - way old school (100 years ago!) but a treasure trove of excellent data and instruction. Ask here, there are many who would be tickled pink to help. |
#22
I suggest getting a surplus mill or lathe from a regional machine shop or manufacturer or workshop enthusist. We have three machines (two free) with a complete set of tools with a total investment of ~$1K plus a trailer rental for a 300 mile one way travel. It can be done on small budget like yours. Our equipment ranges in age from 20 to 40+ years but they are in full working order. Each unit has some quirks/idiosyncrasies which can be overcome by testing and measuring the results.
#23
Also, if you do have your drill press set up with one of these, do you just use an edge finder in the drill press the same way you would on a mill? |
#24
I recommend pneumatic rivet pullers and other pneumatic tools. They are usually more compact and can produce higher speeds.
#26
I will second the many suggestions in this thread to look to the used market. Be patient, and you'll find some great deals. My team got a FANTASTIC deal on a great quality off-brand Series 1 mill clone, with DRO, work holding, and X power feed included, for $700. We've also gotten a 12" lathe at a used tool shop for $600, and had a smaller lathe donated. |
#27
Are you planning this for this season? If so buy to mach your skills. If your team has lathe skill but not milling than buy a lathe. The same goes for mill or 3d printer or any other tools. It is not worth trying to learn how to use a tool during build. A mentor with sheet metal skills can do more for a team teaching the students with a shear and a brake then mill taking up need valuable time during build.
#28
Not to pile on top of the previous comments, but also note that drill chucks are unable to safely sustain radial loads, even when used in a proper milling machine.
Some tiny benchtop milling machines do have morse taper spindles, but they are designed for (small) radial loads, and include a drawbar like a regular milling machine would have. On topic - used is the way to go with your budget, but make sure you have someone familiar enough with a mill/lathe to make sure it's in decent operating condition. A beat to death bridgeport with a ton of backlash wouldn't be ideal. |
#30
On backlash: it's not a huge problem if you have a DRO and a reasonably heavy mill. I've been meaning to ask our maching mentor about tightening up the backlash on our Bridgeport, as it currently has around 0.060" of backlash. It has never been a problem for us as we only take light to medium cuts in aluminum, so as long as you're careful and don't heavy climb mill it should be fine. I agree that somebody knowledgeable about mills/ lathes whould go with you. Take along a checklist or something at the very least. Make sure that there's no rust in the spindle or on the ways, that it's not pitted to oblivion and flat, etc. |
