Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Unread 21-11-2014, 12:48
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Monobolt rivets on FRC applications
We have been looking into using monobolt rivets on our high vibration and impact mechanisms like a drive train. We used all aluminum last year and had a terrible time with them popping, loosening, stretching, and a ton of shearing. We are testing steel rivets and the monobolts to see if we see improvement. Just wondered if anyone has seen/heard/used them.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 21-11-2014, 13:25
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Monobolt rivets on FRC applications
You can use Hugh strength rivet . Which should hold a lot better.
R.C.
MadTown Robotics Team 1323
Unread 21-11-2014, 14:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Yes you want to use a structural or aircraft grade rivet (like the monobolt) that locks the stem into the body of the rivet. Not the big box store variety rivet.
If the rivets are stretching/loosening then they aren't big enough or enough of them.
Unread 21-11-2014, 14:06
AdamHeard's Avatar
Lead Mentor
It really depends on how you're using them.
There is nothing wrong with regular rivets, they just aren't as strong... So design accordingly.
Use gussets with more rivets, etc...
It's also nice in some ways to design for regular, knowing you can switch to the stronger rivets if you need to (or switch to steel).
Unread 21-11-2014, 17:55
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Agreed. 3/16" aluminum rivets are rated for 310 pounds of shear strength and 500 pounds of tensile strength. Going to steel bumps those numbers up over 2x the aluminum rating. A few more well placed aluminum rivets can add a lot of strength.
One word of caution if going the steel rivet route, we used steel rivets in a high load application and they were a bugger to drill out. After they were out, they were replaced with aluminum rivets without failure during use.
Unread 23-11-2014, 10:51
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Ty! We were using 5/32" aluminum rivets and gussets; filling every open hole on our gussets. I we are already for sure going with 3/16" rivets next season and hope that helps. We will be putting 3/16" steel rivets on our off season bot and see how they hold up.
Unread 23-11-2014, 15:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
We use 1/4" rivets for the main chassis, where the load will be for crashes etc. We use 1/8" rivets everywhere else. THe only place I saw a 1/4" rivet fail was on our catapult arm, where the gusstens on the arm began to pull off of the 2x1. Fortunately, we caught it and replaced the arm with a welded one post-season.
Unread 23-11-2014, 15:55
Deke's Avatar
no team (No Team)
I am curious on the decision to go with 1/8" diameter rivets, is there a reason for going to that size?
It doesn't have much of a weight savings and they are significantly weaker than larger diameters.
Unread 23-11-2014, 17:46
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
The main reason we go 1/8" whenever possible ise because we have a pneumatic riveter for 1/8" rivets and small hand riveters for 1/8" rivets.
Our only 1/4" riveter is a very large tool by comparison, so if something breaks it takes more time to rivet it. It's almost impossible to use the 1/4" riveter on the robot.
Occasionally we use 3/16" rivets as the small hand riveters and pneumatic riveter work with those, like on our pickup arm this year.
Unread 24-11-2014, 00:52
Another one is that if a steel rivet fails, it will more likely elongate your hole because the rivet is stronger than the material it is in. That means that you'll have more trouble putting a rivet back in. We use only aluminum rivets for that reason.
We found countersunk rivets a couple years ago, and have fallen in love.
Unread 24-11-2014, 01:34
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Is that what you guys used on your intake gussets this year?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 24-11-2014, 08:31
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
What is the reason for welding and using rivets with gussets? I have noticed you guys do this in a few areas. I would assume for extra strength and rivets/gussets make alignment pretty good while welding?
-Ronnie
Unread 24-11-2014, 09:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Any issues with corrosion when using a steel rivet on an aluminum frame? If so, how long does it take to become an issue? Just curious when to retire use of older robots from "playing defense" against newer robots.
I'll note that the #1 reason our rivets have repeatedly failed in the past (2010 frame, 2012 arm, 2013 wheels) is due to an incorrect drill bit size when drilling the initial hole (less common) or when replacing a failed rivet at competition (more common).
Unread 24-11-2014, 11:05
Lead Bumper Mentor
AKA: Mike Marandola
-Ronnie
I can't speak for 254, but I would guess added strength. Some parts on their intakes, like the little machined hinges, had to be welded anyway so why not? It is very minimal effort. Additionally, you would want parts that go outside your frame to be as rigid as possible to be able to withstand impacts.
Unread 24-11-2014, 11:30
Oblarg Oblarg is offline
AKA: Eli Barnett
Speaking of stuff done in addition to riveting, one of our new mentors advocated using adhesive in addition to rivets on our tube-and-gusset constructions. We're doing this now, as it should reduce wear on the rivets/holes during impacts.
Just wondering if any teams have done something similar, and, if so, how effective they found it to be.
"The breakfast of champions!"
