Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 24-11-2014, 12:47
Re: Monobolt rivets on FRC applications
Originally Posted by Mike Marandola View Post
Is that what you guys used on your intake gussets this year?
Yes, those are countersunk 3/16 rivets.
Originally Posted by Ronnie314 View Post
What is the reason for welding and using rivets with gussets? I have noticed you guys do this in a few areas. I would assume for extra strength and rivets/gussets make alignment pretty good while welding?
-Ronnie
The extra strength isn't part of the reason. They are riveted before welding so that the parts are pre-jigged when they arrive for welding. That makes it easier to get a better result.
Unread 24-11-2014, 15:04
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Got ya. I was wondering if that was the reason since we do the exact same thing.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 24-11-2014, 16:59
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
I can't speak for 254, but I would guess added strength. Some parts on their intakes, like the little machined hinges, had to be welded anyway so why not? It is very minimal effort. Additionally, you would want parts that go outside your frame to be as rigid as possible to be able to withstand impacts.
We do this mainly for fixturing purposes. It makes the welders life much easier.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 24-11-2014, 17:04
Joining the 900 Meme Team
FRC #0079
I am not a Mech Eng but I do want to point out the opposite of this thought. Rigid is great but there comes a point where you can't make it rigid enough. At that point you should look into making it flexible. For example, the 16 beater bar intake is wonderful because it is nearly impossible to break. I've seen them rotate around 180 degrees without failure.
Unread 24-11-2014, 20:49
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
That was my second thought. I was close to linking this thread were it was discussed.
I know my statement was pretty broad, but I think it greatly depends on the device. Some devices you would need rigid and some would benefit from added flexibility.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
