Thread Tools |
Rating:
Display Modes |
Re: Electronic scouting using 7 laptops and a little mysql
All our students are issued iPads (wifi, no cellular, not sure about bluetooth-- I would think so). Are there any existing scouting applications out there that would take advantage of this?
525 Swartdogs have an apple scouting app: Aerial Scout KnightKrawler built and maintains their own android scouting app: FRCKrawler Nate |
It is quite difficult to use tablets, specifically Apple tablets in the field as you are not allowed to use WiFi and Bluetooth. Some Android tablets, however, have the ability to connect an ethernet cable. I believe that e-scouting is quite reserved to laptops, which have some unbeatable features:
Not allowed to use bluetooth? I thought there was nothing in the rules prohibiting bluetooth use.
It's not safe to use Bluetooth. It runs at 2.4GHz so the staff can prohibit Bluetooth if they think it is necessary!
Source?
#7
http://en.wikipedia.org/wiki/Bluetooth.
Bluetooth runs at the same spectrum as WiFi, the communications used by the FMS. You can guess that there will be some sort of interference that will occur. http://en.wikipedia.org/wiki/Electro...nce_at_2.4_GHz Last edited by yash101 : 26-11-2014 at 22:41. |
#8
Relevant Q&A from last year:
On top of the response you just got, I point you to the following threads from within the last year.
http://www.chiefdelphi.com/forums/sh...d.php?t=129261 http://www.chiefdelphi.com/forums/sh...d.php?t=127877 (briefly) http://www.chiefdelphi.com/forums/sh...d.php?t=126509 (I thought the same, though was less set in opinion) http://www.chiefdelphi.com/forums/sh...d.php?t=124721 (and this one is calling you, Yash, because not only does it cover tablets, but you made post #7. ) |
#10
Of course there are technicalities and ethical reasons against using bluetooth, but none are explicitly stated in the rule itself. *Note* 2014 and prior rules have no bearing on the 2015 rules and are subject to change by FIRST |
#11
False. See Quote:
Obligatory disclaimer: 2015 rules may differ. Last edited by Chris_Ely : 26-11-2014 at 22:41. |
