Go to Post Not every team can start 200 teams in Canada or Hawaii because they are located in relatively dense region of teams already. This doesn't mean they can't impact their local and surrounding areas. This is where you have to be creative. - tim-tim [more]
Unread 25-11-2014, 00:14
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
2073 is looking into WCD, feedback requested
Up until now, we have mostly been a KOP drive base shop. KOP on Steroids has been our main chassis for the last few years. We are now looking into switching it up and moving to WCD.
Here is are a couple of renders of our first attempt.
I am not a CAD master by any means, this is done by one or more of our students. I am going to ask them to follow up on any/all questions and suggestions.
We had originally thought we would try to have a single drive belt contained in the frame rails, but found that a single serpentine belt needed to wrap around idler pulleys that were way smaller than the minimum recommended by Gates. So, now we plan on using one internal to, and one just inside the frame rail.
Any comments, critiques, questions, or suggestions will be greatly appreciated.
Full size images can be viewed here and here.
Unread 25-11-2014, 01:05
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: 2073 is looking into WCD, feedback requested
It's a really nice rendering in any case!
I have no experience with WCD, but your design seems pretty textbook - just missing the shaft collars / circlips needed to hold the wheels on to the hex shafts.
Unread 25-11-2014, 01:17
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
From what I see it looks good. Like others have said its just missing an clip ring or shaft collars. Everything looks to be functional and it looks beautiful! Best of luck!
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 25-11-2014, 01:31
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Howzit!
We started using WCD last year and really like the performance. So unless the game dictates otherwise we will be using it again, though possibly a hex frame 8 wheel WCD.. I posted earlier
A few things.. Top render has the transmission constrained on the wrong side of the drive rail.
You will be better off not using the versa blocks on the center and just drilling your center hole to use the WCD gearing block.
http://www.wcproducts.net/217-3634/
You will also need to drill a few holes on the drive rail for the bolt heads on the transmission plate to nest into. This will allow the transmission plate to rest against the drive rail giving much better support. You can run a dual sprocket on the transmission to drive each of the outer wheels.
I suggest #35 chain. We have been using #25 but last year we had to tension the chain more often due to our use of the WCD 3 CIM dual speed transmission. (great transmission by the way)
Also factor in a chain/belt cover. Nothing is worse than an electrical wire getting in there. Most of the time an encoder is mounted to one of the outer wheel shafts. Plus the judges like things to be safe!
I am sure I will think of more after I post this..
Good luck with this, looking good!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 25-11-2014, 02:14
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Bill,
We should arrange an in-person design review in December. It would be a great experience for both teams. We're not too far away after all
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 25-11-2014, 02:58
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Aloha
+1. Some inspectors will not like the uncovered chain, but more importantly stuff can get snagged in there really easily.
Also, when doing renders, turn on perspective. It makes it looks a little more realistic.
Unread 25-11-2014, 07:29
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
I'm unsure if the little tabs on the edges are for bumpers but if they are I would either come up with a way to support them or a beefier way because I could see though bending easily if a team gets under you bumpers. Aside from that looks good
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 25-11-2014, 07:51
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
...Top render has the transmission constrained on the wrong side of the drive rail...
I saw that too, but I think that is just the wheel reflection in the frame rail.
Looks great to me, once you figure out chain/belt runs you should be set. We have had a harder time figuring out chain/belt runs than anything else building our first in house drive train.
BTW, your RSL is hanging outside your frame perimeter...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 25-11-2014, 09:00
FRC #1836 (MilkenKnights)
First of all, there is no pulleys on the inside of the gearbox for the two back wheels.
In tube belts is going to be a nightmare to fix. With a regular WCD, the spacers in the gearbox make it harder to fix belts, but doable because you can always just remove the back plate. With this setup, you have to remove the entire gearbox to replace the in-tube belts.
Unread 25-11-2014, 09:09
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Keeping in mind that it has the 2014 controls.... Anything under the CIMs is going to be hard to access. You would also want to make your radio platform easy to remove so you can get to PD board. Depending what ends up on top, you might want to face your pneumatic controls & gauges out. The disconnect switch looks a little buried. You obliviously have a little rearranging to do to make the belts work.
Unread 25-11-2014, 09:26
billbo911's Avatar
Originally Posted by Michael Corsetto View Post
Bill,
-Mike
Excellent idea! I know we plan on meeting with your team leadership to discuss CCC, maybe we can coordinate both things happening at once?
Everyone else, THANKS!! Please continue the feedback!
Great observations and suggestions so far. Correcting these details will go a LONG way to make this a successful endeavor!
Unread 25-11-2014, 09:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It looks like this setup only mounts the WCP gearboxes via 2 #10 bolts. Could you or your students provide an exploded view, or a close-up view, of the gearbox, rail, intended bearings, and all bolts around one side of the bot's center wheel? Making the rail transparent or semi-transparent would also help.
Unread 25-11-2014, 09:36
billbo911's Avatar
I'm working with the student who created this to get his CD account set up so he can respond directly to these questions. The team is out of school this week, so communications are a bit slow. I hope to have him up on the board later today.
Thanks for the request JesseK, we will work on getting that up ASAP.
Unread 25-11-2014, 13:25
Looks like you have ~1" between the bumpers and the wheels. Consider pushing your wheels out a bit further. That'll give you more room inside the base for your electronics.
Why not stand the battery upright? The bumpers will extend to the top of the battery anyways, and you gain a bunch of space back.
The 20/30 amp fuses are hard to get to and see. Move the radio up a lot, or somewhere else.
Considering that the electronics will change next year, can you get models of them and try fitting them into your base instead? That'll be more valuable (and they are smaller!)
Unread 25-11-2014, 13:30
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Bill,
The things I would change:
-Don't use a full versasblock per gearbox, use 1/2. And mount the gearbox so the face of the gearbox is flush.
-Use the WCD 2 CIM DS and ditch the belts inside the tube. Go to 18T sprockets and run chain, you'll be much happier. If you still want to run belts, I would read some of the posts/docs on here about tooth size and width of belts.
I would comment on the electronics layout but Austin has me beat!
R.C.
MadTown Robotics Team 1323
