Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 24-11-2014, 08:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Java Presentations
Here are the two Java presentations that Triple Helix gave at this past weekends FIRST VCU Workshops.
Unread 24-11-2014, 23:24
Re: Java Presentations
FYI, they are moving away from CommandBase, to be more like RobotBuilder. Subsystems are constructed in Robot.
Unread 25-11-2014, 05:55
Flywheel Police
Good to know. I've never been a fan of doing it in CommandBase as it always made more sense to do it in Robot. I however do not like hot RobotBuilder declares all of the sensors and motors in RobotMap, do you know if this is going to continue? If not we might actually move to using RobotBuilder.
I'm working on a second version of the presentation that removes CommandBase from the equation. I'll post when I finish it.
Unread 25-11-2014, 10:05
Flywheel Police
Here are updated versions of the presentations. I have included the code that was to be written as part of the presentation for the beginner presentation along with including a version that takes CommandBase out of the equations.
File Type: pdf Beginner Java for FRC - Without Command Base.pdf (137.0 KB, 69 views)
Unread 25-11-2014, 12:02
I think that's a goal, but there's other higher priority tasks. See http://firstforge.wpi.edu/sf/go/artf1647
Unread 25-11-2014, 12:05
Flywheel Police
Cool, I'll make sure to check it out at the beginning of the season and see if it has been changed. It looks like they plan on getting rid of the RobotMap file completely, I actually like it for storing the channels that all of the different sensors/motors use.
