Go to Post This makes me want to squeal like the teenage girl I am. - ZipTie3182 [more]
  #31   Spotlight this post!
Unread 25-11-2014, 03:55
Andrew Lawrence
Posts: n/a
Re: One speed vs Two speed gearboxes
Originally Posted by asid61 View Post
You don't need full autoshifting. Just enough such that your driver doesn't blow the breaker.
Or just design your robot not to trip and make sure your drivers know its limits.
  #32   Spotlight this post!
Unread 25-11-2014, 09:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Rauhul Varma View Post
I would beg to differ on all accounts. You can definitely make light and small 2 speed gearboxes. Additionally the amount of air required to shift is extremely small, for example the volume of air required for a single shift on 192's 2014 gearbox was (9/16)^2 * pi * 3/8 = 0.373 in^3 of air, which is nothing as many tanks hold around 35 in^3 of air.
Even if some teams can find ways to minimize the additional costs in space, weight, and air doesn't mean they don't exist. By default, adding the additional gearing and shifting mechanisms will take up more space and weight than not having them. By default, triggering a pneumatic cylinder to shift will consume more air than not triggering that cylinder.
Heck, some teams might not even install a pneumatic system if it weren't for two-speed drivetrains.
  #33   Spotlight this post!
Unread 25-11-2014, 10:54
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I agree with the posters that say you can't decide this until you've seen the game.
Autoshifting is done by either current sensing or heat sensing on the main breaker.
I've considered designing a mechanical 'flyball governor' to autoshift. Have any teams ever fielded one of these? Seems easy enough to conceive of. No air, no software and it would down shift when you got slower automatically.
  #34   Spotlight this post!
Unread 25-11-2014, 16:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I can see why you would do that, but that severely limits your speed. A 20fps+ drive can trip in seconds, and even an exeperienced driver can make mistakes (see: 1678). To prevent that you have to cap out your speed, thus limiting your competitiveness. One less thing for the driver to worry about IMO.
  #35   Spotlight this post!
Unread 25-11-2014, 17:07
Andrew Lawrence
Posts: n/a
Team 71 won a world championship with a dominant robot in 2002 spending the majority of the match traveling only inches each second. If you think you need 20+ ft/s to be successful in FRC I suggest you take a step off the California powerhouse hype train and re-evaluate what a drive system is supposed to do. Better yet, attend my class on Strategic Design at the WRRF workshops on December 13th and I will personally explain to you why this isn't necessary.
I understand where you're coming from - I once had a similar mindset as well - luckily I had some good mentors knock some sense into me. We're fortunate to have some of the best mentors to learn from here in California - especially in the Silicon Valley.
  #36   Spotlight this post!
Unread 25-11-2014, 17:13
Joining the 900 Meme Team
FRC #0079
In a time when moving was a major challenge and almost everything was custom and there was less power available in the KoP. Things were slower then.
  #37   Spotlight this post!
Unread 25-11-2014, 17:28
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
If I understand correctly, asid61's stated hypothesis is this: limiting speed reduces competitiveness.
In the context of Aerial Assist, I agree with this. I believe our speed on the field was a component of our success this season.
All aboard the California powerhouse hype train. Next stop, Einstein 2015
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #38   Spotlight this post!
Unread 25-11-2014, 17:36
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
-Mike
I agree, I think speed was one of the factors that separated a good team from a great team. 1678 is a perfect example of this.
2012 - 2015 : 624 CRyptonite
Team Website
  #39   Spotlight this post!
Unread 25-11-2014, 17:37
Andrew Lawrence
Posts: n/a
-Mike
For Aerial Assist, if your strategy played that way it is very true, however it's dangerous to think that an extremely high speed is required for all games, and that was the point I was trying to get across to asid61. Your strategy for this year was more successful with a higher speed and you pulled it off amazingly well. That being said, running your same speeds in a different year - 2012, for instance - may not play as well to your strategy than slightly lower, more controllable speeds. Of course I know you understand this, but I'm posting this to clarify for asid61.
  #40   Spotlight this post!
Unread 25-11-2014, 17:38
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
I was watching one of the Behind The Lines videos which was on drive train design and they discussed modifying a 2-speed shifting gearbox to be one speed and when you shift, the motors run a different system on your robot. This is great for a game where you are either driving or doing another high load/speed task. For example, climbing in games like 2013 and 2010. Has anyone done this before? How effective was it?
  #41   Spotlight this post!
Unread 25-11-2014, 17:47
Look for "PTO" gearbox in search. Power Take-Off rigs allow the full power of the drivetrain (or half of it) to power something else. They've been used as far back as 2004 (60 and 254 winched themselves up to a bar with a PTO from their drivetrain, as I recall). They can be very, very effective, but only if used properly. For example, you probably never want to be driving at the same time the PTO system is on; you could do some serious damage to your robot!
You could also modify a 2-speed gearbox to be a 3-speed, with the third speed being the PTO.
  #42   Spotlight this post!
Unread 25-11-2014, 19:00
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I understand many games require slowness. 2002 is not a good example, as IIRC there was only two cims in the KOP. Going 20fps was not an option. Now, 2010 was a year where speed was not very applicable, and where I think a single speed drive would make sense.
However, for games 2011-2014, fast robots are good. And to go fast and avoid trips (even accidental ones) you should really have a shifter.
Now 2012 I could see going under 20fps. However, six cim drives make going under 18fps almost pointless if you don't have to worry about breaker trips. So you slap on a shifter. The game is not just speed, it's distance/time. The greater that ratio is, the more maneuverable a robot is (depending on the driver, of course).
The primary downside of a shifter is space usage. Custom options are good for this. A team that needs to every inch of space on their robot for manipulators, etc. would need to go non-COTS.
  #43   Spotlight this post!
Unread 25-11-2014, 19:15
Jared's Avatar
Jared Jared is offline
Team 118 didn't shift in 2011, 2012, 2013, or 2014. They were still incredibly good in each of those years. They prove that you don't need 2 speeds to win the same way that Einstein proves, year after year, you don't need an omnidirectional drive to win.
  #44   Spotlight this post!
Unread 25-11-2014, 20:05
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Yes, they were good. But could they have been better? That's not said as a challenge, but I am legitimately interested in why they go with a single speed over a two speed.
As a counterexample, 254 has been shifting for about a decade now, and they have two championship wins.
I would like somebody from 118's opinon on this.
  #45   Spotlight this post!
Unread 25-11-2014, 20:34
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Can I visit the magical world where this is the case?
I feel like what you've been saying about extremely high gears is true if and only if power management is not a concern.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
