Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 25-11-2014, 13:41
philso philso is offline
FRC #2587
Re: 2073 is looking into WCD, feedback requested
Originally Posted by mlantry View Post
I'm unsure if the little tabs on the edges are for bumpers but if they are I would either come up with a way to support them or a beefier way because I could see though bending easily if a team gets under you bumpers. Aside from that looks good
It looks like you are using 2 x 1 inch tubing for the frame and the "stubs" between the wheels for supporting the bumpers. If you are anticipating playing a hard hitting game like this years, the bumpers may "pivot" inward on the top edge of the stubs and the front and rear cross members when hit hard. You may want to consider stacking another piece of 2 x 1 on top of the stubs and the front and rear cross members. Some spacers may be needed where you have the gusset plates. Alternatively, use 3 x 1, or larger tubing.
Originally Posted by FrankJ View Post
Keeping in mind that it has the 2014 controls.... Anything under the CIMs is going to be hard to access. You would also want to make your radio platform easy to remove so you can get to PD board. Depending what ends up on top, you might want to face your pneumatic controls & gauges out. The disconnect switch looks a little buried. You obliviously have a little rearranging to do to make the belts work.
It would be best to locate the battery and input breaker at the end with the PDB and the motor controllers and rotate the PDB by 180 degrees to minimize the lengths of the high current paths. Ensure that you do not cut off access to the battery with your upper structure. Use the space between the CIMs to run wires between the two halves of the chassis. Allow at least an inch of space along each side of the PDB and the Digital Sidecar to allow for the wiring in and out. I would suggest allowing the same clearance around the new RoboRio.
You may want to locate the CRio and Digital Sidecar together on one side, say where you currently have pneumatic valves and compressor. Locate the compressor where the air tanks are now. The air tanks are pretty light so they can be put in the middle or up on the upper structure. You may want to install the pneumatic gauge higher up and turned around (as Frank suggested) so it can be seen over the bumpers.
Moving the radio to the other end will put it closer to the CRio that it connects to and away from potential noise sources (motor controllers). If possible, mount the radio on a light piece of plastic in a space in the upper structure so that it is physically protected and not surround it with metal (for better reception).
Unread 25-11-2014, 17:38
Saool's Avatar
Saool Saool is offline
AKA: Sohail Ahmed
FRC #2073 (EagleForce)
Saool is an unknown quantity at this point
Thank you for the feedback. Yes the little tabs are for the bumpers. Throughout the 2014 season we used a similar fashion for mounting the bumpers. How do you suggest we support them? I felt like keeping them away from the edge would allow them from being bent by having all the force of impact be disbursed throught the 2x1. Any suggestions would appreciated.
Unread 25-11-2014, 17:49
Saool's Avatar
AKA: Sohail Ahmed
Originally Posted by AustinSchuh View Post
Looks like you have ~1" between the bumpers and the wheels. Consider pushing your wheels out a bit further. That'll give you more room inside the base for your electronics.
Why not stand the battery upright? The bumpers will extend to the top of the battery anyways, and you gain a bunch of space back.
The 20/30 amp fuses are hard to get to and see. Move the radio up a lot, or somewhere else.
Considering that the electronics will change next year, can you get models of them and try fitting them into your base instead? That'll be more valuable (and they are smaller!)
Thank you for the feedback. I will work on moving the wheels out more, it will definitely help with getting more space inside the frame. Standing the battery upright was done at first and i simply forgot about it, that will for sure be done. As far as cadding in the new electronics goes i have done that and its simply a seperate render. After putting those in there is alot more space also considering the new speed controllers are stackable. Anything more advise will be highly appreciated. Also the reason for using old electronics is this will possibly be used as a practice run for our first WCD, i dont beleive we will be buying the new control system for it.
Unread 25-11-2014, 18:07
Saool's Avatar
AKA: Sohail Ahmed
Originally Posted by TikiTech View Post
Howzit!
We started using WCD last year and really like the performance. So unless the game dictates otherwise we will be using it again, though possibly a hex frame 8 wheel WCD.. I posted earlier
A few things.. Top render has the transmission constrained on the wrong side of the drive rail.
You will be better off not using the versa blocks on the center and just drilling your center hole to use the WCD gearing block.
http://www.wcproducts.net/217-3634/
You will also need to drill a few holes on the drive rail for the bolt heads on the transmission plate to nest into. This will allow the transmission plate to rest against the drive rail giving much better support. You can run a dual sprocket on the transmission to drive each of the outer wheels.
I suggest #35 chain. We have been using #25 but last year we had to tension the chain more often due to our use of the WCD 3 CIM dual speed transmission. (great transmission by the way)
Also factor in a chain/belt cover. Nothing is worse than an electrical wire getting in there. Most of the time an encoder is mounted to one of the outer wheel shafts. Plus the judges like things to be safe!
I am sure I will think of more after I post this..
Good luck with this, looking good!
Aloha
Thank you for the feedback. At first we were planning on using a single belt that ran inside the 2x1 but were promptly met with many issues. In this render we were planning on having the back to center wheel's belt on the inside of the frame and the front to the middle inside the tubing. We planned on using belts because of their minimal stretching, but after recieving all this feedback to switch to chains, we will probably be doing so. I will be cadding a cover too and will update the render with all the great suggestions. As far as the gearing block goes we have already ordered them before break and i will propose buying those to our instructor. The render issue you saw was simply a reflection issue but the transmissions still need to be editted to include a sprocket on the output shaft. I will hopefully have the updated render in by tonight.
Unread 25-11-2014, 18:09
Saool's Avatar
AKA: Sohail Ahmed
Originally Posted by MrBasse View Post
I saw that too, but I think that is just the wheel reflection in the frame rail.
Looks great to me, once you figure out chain/belt runs you should be set. We have had a harder time figuring out chain/belt runs than anything else building our first in house drive train.
BTW, your RSL is hanging outside your frame perimeter...
The simple things always count! Thank you for your feedback, i will edit that part.
Unread 25-11-2014, 18:17
Saool's Avatar
AKA: Sohail Ahmed
Originally Posted by JesseK View Post
It looks like this setup only mounts the WCP gearboxes via 2 #10 bolts. Could you or your students provide an exploded view, or a close-up view, of the gearbox, rail, intended bearings, and all bolts around one side of the bot's center wheel? Making the rail transparent or semi-transparent would also help.
Thank you for your feedback. Yes the gearboxes are mounted on by only 2 bolts, i was wonderig of a way to fix that and R.C. has responded with a great idea. I will be editting the cad to allow better contact. If you would still lile to see the exploded view let me know and i will happily render it out with the frame's transparency changed, it just that knowing we will probably be changing to chain it we wont have that issue any longer
Unread 25-11-2014, 19:11
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
If you are concerned about running chains inside the frame perimeter you can easily put the sprockets on the back of the wheels and run the chain system that way. It will reduce the interior available space but will eliminate the need for chain covers. The chain covers will reduce the interior space available so in reality it about the same amount of space. If you like I can send you our CAD from last year.
Here is one of our CAD models with chain runs behind the wheels. Pardon the overly large sprockets.. We ended up moving the chain to the interior for that year.
http://www.chiefdelphi.com/media/img...9ae90ccd_l.jpg
Last year we used the WCP 3CIM DS transmission with chain runs inside the frame perimeter. We installed chain covers, like on a bicycle. The chain covers worked just fine but this year we are going to run the sprocket & chains in the frame..
http://www.chiefdelphi.com/media/img...e70e30e9_l.jpg
Keep it up!!
Aloha
Mr H.
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 26-11-2014, 13:27
Saool's Avatar
AKA: Sohail Ahmed
Keep it up!!
Aloha
Mr H.
I would love to see your cad from last year to reference the chain idea. Being our first time with WestCoast, anything will help!
Unread 26-11-2014, 14:29
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Do you have the center wheel dropped lower? If so, how much lower? I think I have seen some teams that did not drop their center wheel, how much of a difference is this? Is it beneficial or not? For those that did not drop the center wheel, would you recommend it?
Unread 26-11-2014, 17:37
billbo911's Avatar
AKA: That's "Mr. Bill"
The current design has a .125" drop.
Many of the suggestions here have been incorporated into an updated version. I will see if I can get the improved version up soon.
Unread 26-11-2014, 17:56
TikiTech's Avatar
Mr. H
If there is no drop center you will run into scrubbing (robot hopping from the outer wheels having too much traction to allow smooth turning). I have seen the use of Omni wheels to resolve this on a non dropped WCD.
1/8" drop is the norm for the center wheels. If you keep the weight centered well enough, spinning around is very easy! As mentioned, even when weight is not centered, on a drop center drive the robot will rock to one end and essentially be 4wd with a short wheelbase, which will turn much easier with less scrubbing than 6wd non drop..
Yeah robot doughnuts!
Aloha!
Unread 26-11-2014, 20:18
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'd recommend using colsons and then shaving down the center wheel till happy with your drop. We started out with 3/32 and ended up with 1/16 or none.
R.C.
MadTown Robotics Team 1323
Unread 26-11-2014, 22:17
billbo911's Avatar
Did you find 1/8" gives too much rocking of the chassis?
By intentionally shaving down the center wheel, which usually wears down fastest anyway, aren't you introducing a different effective FPS from the center wheels than the front and rear wheels? I know this is done on purpose with some 4x4 vehicles to increase traction on surfaces that will allow slippage, like sand or gravel. Are you suggesting to do this as a way to determine optimum drop, or something else.
Unread 26-11-2014, 23:09
TikiTech's Avatar
Mr. H
^THIS ^
We started with 1/8" and kept it. By championship it was worn close to 1/16th and ran like a champ.. Though might of been that WCP 3CIM DS transmission...
With the deformation of the carpet and the Colson wheels, it was ready to go at 1/8" !
I will get the CADs up over the long weekend.. like the end of it because the weather is great!
Aloha
Unread 27-11-2014, 00:26
billbo911's Avatar
Thanks everyone who gave suggestions and comments. This is almost becoming a "Design by Community" project.
Here are two new renders. Most of the suggestions have been incorporated now. In the oblique projection, we noticed the tension cam is on the wrong side of the block. Ooops! It is corrected in the overhead render.
Full Res images here and here.
