Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
  #46   Spotlight this post!
Unread 25-11-2014, 20:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: One speed vs Two speed gearboxes
Originally Posted by z_beeblebrox View Post
Can I visit the magical world where this is the case?
I feel like what you've been saying about extremely high gears is true if and only if power management is not a concern.
It's called a shifting gearbox.
My point is that with a shifter you don't need to worry about power managment, as long as you are either a) careful and shift or b) use encoders or other methods to automatically shift down in collisions. I prefer the latter method, as the first has much less use.
  #47   Spotlight this post!
Unread 25-11-2014, 20:43
AdamHeard's Avatar
Lead Mentor
Originally Posted by Michael Corsetto View Post
If I understand correctly, asid61's stated hypothesis is this: limiting speed reduces competitiveness.
In the context of Aerial Assist, I agree with this. I believe our speed on the field was a component of our success this season.
All aboard the California powerhouse hype train. Next stop, Einstein 2015
-Mike
Chooo Chooo!
I think it's fair to argue for 95+% of teams the difference between a 16fps high gear and a 20+ fps high gear is not what will make them more competitive.
Gearing that high requires a higher attention to detail mechanically, as well as a good supply of batteries. Many teams don't realise their batteries are in bad shape because their robots simply don't use that much juice.
  #48   Spotlight this post!
Unread 25-11-2014, 20:59
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Originally Posted by asid61 View Post
So you slap on a shifter.
I don't know of any teams that can just "slap on a shifter" without any substantial time commitment from their build team. Additionally, shifting necessitates both more coding time and more practice time for the drivers. Shifting is a tradeoff, just like every other part of the robot. No robot will instantly just become better if a shifter is just slapped onto it.
Maybe I am reading too much into your words asid, but it seems to me that you believe that every robot would instantly just be better if a shifter were used instead of a single-speed. On a team with infinite resources, this might be the case, but on my team at least, we always have to make tradeoffs in our designs, and we will likely not be using a shifting gearbox next year so that we can focus on other aspects of our robot.
  #49   Spotlight this post!
Unread 25-11-2014, 21:00
AdamHeard's Avatar
Lead Mentor
Arguably you can slap one of these on just as easily as slapping on a single speed.
http://www.vexrobotics.com/vexpro/ge...llshifter.html
  #50   Spotlight this post!
Unread 25-11-2014, 21:06
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
As a matter of fact, it's can be kind of hard to do that on a ballshifter. We are planning out a test WCD (again) this year, and we found it hard to integrate a ballshifter without having to make our own bearing blocks. We could add our own bearing blocks, but we wanted to try as much COTS as possible, so we're actually going with a WCP shifter for the chassis. But depending on the chassis, WCP or Vex is easy.
Shifting gearboxes do cost a lot of cash, as far as resources go. More coding, okay, more practice, okay. However, both of those can be done pre-season as long as you release the code for the shifting as open-source. Other things might be a higher priority, but if you have the money and pre-season time it definitely worth it.
  #51   Spotlight this post!
Unread 25-11-2014, 21:12
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Originally Posted by Abhishek R View Post
I agree, I think speed was one of the factors that separated a good team from a great team. 1678 is a perfect example of this.
As a counterpoint, though, for most teams - who don't build a practice bot and therefore don't have the time to train a driver for super-high speed manuvering or develop robust autoshifting code - super high ( I view that to be above the 16-17 fps range) speeds can be absolutely terrible.
Case in point: Us last year. While our drive was a monster and for the most part dominated the field, our driver was, for our first competition, terrified to drive in high gear because of the high risk of blowing the breaker. It took him the full competition to really get the hang of obstacle avoidance and shifting for plowing.
  #52   Spotlight this post!
Unread 25-11-2014, 21:44
AdamHeard's Avatar
Lead Mentor
The 3 cim ballshifter is designed to mount with half of a versablock set.
  #53   Spotlight this post!
Unread 25-11-2014, 22:57
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
... <facepalm>
Well, we already ordered everything, and it's not like we're any less off for that. WCP is still fine.
We thought we were supposed to use the "gearbox bearing block" like on a WCP box.
  #54   Spotlight this post!
Unread 25-11-2014, 23:00
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
... <facepalm>
You can use the versablock on both actually.The "Gearbox Bearing Block" is just for teams that can CNC a hole/want a smaller bearing block.
http://www.buildblitz.com/final-cad-files/
The Copioli robot should show the setup with Ball Shifters + VersaBlock.
R.C.
MadTown Robotics Team 1323
  #55   Spotlight this post!
Unread 26-11-2014, 00:30
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Chooo Chooo!
Absolutely agree.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #56   Spotlight this post!
Unread 26-11-2014, 01:02
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
-Mike
Chooo Chooo!
I would challenge the notion that a smaller gear ratio will always result in a quicker robot on the field. We did some modeling a couple years ago and found that because of the tradeoff of top speed and acceleration, 16 to 16.5fps free speed with two CIMS and full weight robot is fastest for a half field distance. Our thinking is that for most games, it is rare that you can have an uninterrupted run across the length of the field, and that having top speed here is not worth trading off performance during shorter runs.
We ran this speed last year and were keeping up gamewise with those geared faster. This could be because 2014 game play ended up being much further from an open field than it looked like, but I think another reason to not lose sight of is that once your robot is fast enough, it is more important how it is driven than what the exact speed. Our driver gets a lot of practice, and a fundamental of what we practice is how to accomplish whatever needed in the most efficient means possible.
  #57   Spotlight this post!
Unread 26-11-2014, 02:41
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Chooo Chooo!
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
  #58   Spotlight this post!
Unread 26-11-2014, 03:09
Volunteer, WPILib Contributor
no team (Waiting for 2021)
This year, we had 6 Cims on our drive. During competition season, we were geared for 10.5 fps. With the wheels we had, this was traction limited, and we never got even close to popping breakers. But once we got to the highest level of competition at worlds, we were too slow to be competetive. We switched to 16FPS at IRI. The speeds with this actually allowed us to be competitive with the rest of the field. But in eliminations when our driver was playing rougher defense, we did pop breakers.
I would argue that with 6 Cims, the optimal points are about 10FPS for the low speed, and 16+fps for the high speed. With a 6 Cim drive, 10FPS will allow you to get around your half of the field basically as fast as possible, yet still allow you to not get in trouble with defense. Then if you need to cross the field, or the defender is faster then you, you can shift up to 16+fps and get across field very quickly.
If the field is split like 2010 or 2012, I would argue that a single speed 6 Cim 10 fps robot is the best you can get, because there is not enough room to use any higher of speed. For years like 2011, 2013 and 2014, you want to be able to shift up for extra speed to cross the field quickly. Those are the types of years shifter are useful, because they allow cross field travel faster.
Team 4488 - Mentor 2013-2016
  #59   Spotlight this post!
Unread 26-11-2014, 09:22
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Yes, they were good. But could they have been better? That's not said as a challenge, but I am legitimately interested in why they go with a single speed over a two speed.
As a counterexample, 254 has been shifting for about a decade now, and they have two championship wins.
I would like somebody from 118's opinon on this.
I don't understand this, there are numerous factors as to whether a team wins or not, and I doubt shifting is a major one.
I would hesitate to use wins/losses as evidence to back up certain points, mainly because correlation is not causation.
As a counterexample to your counterexample, 610 in 2013 was extremely competitive to the point that they took home the Championship. They also only used one speed - I recommend looking up their philosophy on that, I believe Mr. Lim and Mr. Rob Stehlik have some in-depth posts about it. Back to my point, personally while I thought they had a very good robot, I would not attribute the win to them having the single best robot on the field, but rather to 1241, 1477, and 610's capability to play as an alliance instead of playing as three teams.
I still believe one choice is not inherently better than another, both have benefits and drawbacks, and it just depends on the game or team preference.
2012 - 2015 : 624 CRyptonite
Team Website
  #60   Spotlight this post!
Unread 26-11-2014, 10:07
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I have to disagree with 6 cim single speed 10fps. You get a maximum of a few hundreths of a second less time to get to a point versus 4 cims, regardless of the distance. If you're gearing for 10fps, I would definitely just use a 4 cim drive.
My example was actually to show that having a shifter isn't uncompetitive, although it's rather rather unnecesary. I wonder how many shifters were on Einstein these past years? That would provide more usable data.
