Go to Post While we all look back and appreciate the shoulders of the giants of the past upon which we are standing, let us not forget that we are the giants of today. Ours are the shoulders on which others will be standing in the future. - Mike Rush [more]
Unread 26-11-2014, 08:18
Re: What's the best charging position for robot batteries?
Well, AGM cells can theoretically be used and charged in any orientation. Gell cells are different, slightly. I recommend that charging take place with the batteries facing up for one reason only. Any water vapor will naturally drop onto the cell pressure seals during inverted charging orientation. If for some reason, the internal pressure causes the seals to open, some of that water will be lost. This is an extremely rare event. Just my way of optimizing battery life. Lost water translates to less contact between electrolyte and plate. Less contact relates to less available current which will lead to shorter usable life.
Unread 26-11-2014, 11:25
DonRotolo's Avatar
Back to humble
FRC #0832
Exactly: Charge upright so you vent gas in the unlikely instance of overpressure venting. Otherwise it makes no difference.
Unread 27-11-2014, 23:51
philso philso is offline
FRC #2587
I seem to recall Enersys telling us at work that if the battery vents while upside down, it may push some of the acid out. This would be more dangerous than just venting the gasses. We use tons (literally) of the 7AHr version of the battery in our UPS' each week.
Unread 28-11-2014, 07:34
Phil,
That is true in gel cell technology but not in AGM. The acid is "locked" into the fiberglass matrix so it is not free flowing except when the case is damaged or some other catastrophic event occurs.
Unread 30-11-2014, 12:14
DonRotolo's Avatar
Back to humble
FRC #0832
Well, yes and no. The 'Glass Mat' into which the acid is 'Absorbed' can be thought of as a fiberglass sponge. Just like a sponge, if you shake it or squeeze it, liquid will drip out. In a venting situation (which is a "catastrophic event" IMHO), it is unlikely the gas will form right at the vent, so it will 'push' some of the liquid out of the 'sponge' and then it can come out of the vent.
That being said, a standard qualification test for automotive AGM batteries is to drill a series of 6 mm (~1/4") holes in the bottom of the case, and NO acid may come out at all. So yes, the acid really does stay in there most of the time.
Now that being said, charge your batteries - Gel, AGM, and conventional -upright please. Spewing acid is not a national emergency, but someone could get hurt.
