#46
Re: One speed vs Two speed gearboxes
My point is that with a shifter you don't need to worry about power managment, as long as you are either a) careful and shift or b) use encoders or other methods to automatically shift down in collisions. I prefer the latter method, as the first has much less use. |
#47
I think it's fair to argue for 95+% of teams the difference between a 16fps high gear and a 20+ fps high gear is not what will make them more competitive. Gearing that high requires a higher attention to detail mechanically, as well as a good supply of batteries. Many teams don't realise their batteries are in bad shape because their robots simply don't use that much juice. |
#48
I don't know of any teams that can just "slap on a shifter" without any substantial time commitment from their build team. Additionally, shifting necessitates both more coding time and more practice time for the drivers. Shifting is a tradeoff, just like every other part of the robot. No robot will instantly just become better if a shifter is just slapped onto it.
Maybe I am reading too much into your words asid, but it seems to me that you believe that every robot would instantly just be better if a shifter were used instead of a single-speed. On a team with infinite resources, this might be the case, but on my team at least, we always have to make tradeoffs in our designs, and we will likely not be using a shifting gearbox next year so that we can focus on other aspects of our robot. |
#49
http://www.vexrobotics.com/vexpro/ge...llshifter.html |
#50
#51
Case in point: Us last year. While our drive was a monster and for the most part dominated the field, our driver was, for our first competition, terrified to drive in high gear because of the high risk of blowing the breaker. It took him the full competition to really get the hang of obstacle avoidance and shifting for plowing. |
#52
Well, we already ordered everything, and it's not like we're any less off for that. WCP is still fine. We thought we were supposed to use the "gearbox bearing block" like on a WCP box. |
#54
http://www.buildblitz.com/final-cad-files/ The Copioli robot should show the setup with Ball Shifters + VersaBlock. |
#55
-Mike |
#56
We ran this speed last year and were keeping up gamewise with those geared faster. This could be because 2014 game play ended up being much further from an open field than it looked like, but I think another reason to not lose sight of is that once your robot is fast enough, it is more important how it is driven than what the exact speed. Our driver gets a lot of practice, and a fundamental of what we practice is how to accomplish whatever needed in the most efficient means possible. |
#57
#58
This year, we had 6 Cims on our drive. During competition season, we were geared for 10.5 fps. With the wheels we had, this was traction limited, and we never got even close to popping breakers. But once we got to the highest level of competition at worlds, we were too slow to be competetive. We switched to 16FPS at IRI. The speeds with this actually allowed us to be competitive with the rest of the field. But in eliminations when our driver was playing rougher defense, we did pop breakers.
I would argue that with 6 Cims, the optimal points are about 10FPS for the low speed, and 16+fps for the high speed. With a 6 Cim drive, 10FPS will allow you to get around your half of the field basically as fast as possible, yet still allow you to not get in trouble with defense. Then if you need to cross the field, or the defender is faster then you, you can shift up to 16+fps and get across field very quickly. If the field is split like 2010 or 2012, I would argue that a single speed 6 Cim 10 fps robot is the best you can get, because there is not enough room to use any higher of speed. For years like 2011, 2013 and 2014, you want to be able to shift up for extra speed to cross the field quickly. Those are the types of years shifter are useful, because they allow cross field travel faster. |
#59
I would hesitate to use wins/losses as evidence to back up certain points, mainly because correlation is not causation. As a counterexample to your counterexample, 610 in 2013 was extremely competitive to the point that they took home the Championship. They also only used one speed - I recommend looking up their philosophy on that, I believe Mr. Lim and Mr. Rob Stehlik have some in-depth posts about it. Back to my point, personally while I thought they had a very good robot, I would not attribute the win to them having the single best robot on the field, but rather to 1241, 1477, and 610's capability to play as an alliance instead of playing as three teams. I still believe one choice is not inherently better than another, both have benefits and drawbacks, and it just depends on the game or team preference. |
#60
