Go to Post the Robotics team isn't just a club, it's a family. - 1086Programmer [more]
Unread 26-11-2014, 11:01
Re: Physics Quiz 10
Originally Posted by dellagd View Post
Yes, via the equation Vt = r * omega
Take your value omega=0.847 rad/sec and use it to calculate the x and y components of carpet speed:
Vcx = omega*(L/2) = 0.847*(2/2) = 0.847 ≠ 0.988
Vcy = 2-omega*(W/2) = 2-0.847*((28/12)/2) = 1.012 ≠ 0.847
Now try omega = 84/85:
Vcx = omega*(L/2) = (84/85)*(2/2) = 0.988
Vcy = 2-omega*(W/2) = 2-(84/85)*((28/12)/2) = 0.847
Unread 26-11-2014, 11:05
Re: Physics Quiz 10
Originally Posted by Jared View Post
cos(tan^-1(12/14) = 0.7593
0.7593*2 = 1.5186 ft/second
Length of diagonal is 3.0731 feet.
Circumference is 3.0731*pi = 9.6544
1.5186/9.6544 =0.1572 rotation/sec = around 1 rad/sec.
In this particular problem, you can get the correct answer -- as you have done -- by simply projecting the wheel speed unto the direction the wheel is moving.
But as the problem gets more general (and more complicated), that will no longer work.
Unread 26-11-2014, 11:42
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Physics Quiz 10
Oh, it would seem that I made a stupid error. I swapped what I used for Wheelbase and Trackwidth. I wasnt sure, so I looked it up online and people were saying that trackwidth is the distance between wheels on a vehicle. It seems thats not what you used here.
I swapped my values in the calculations and my method gave me the correct answer. When I get home I'll repost a correct explanation.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 26-11-2014, 11:57
Re: Physics Quiz 10
Yes, trackwidth is the distance between the 2 front wheels. (Or the 2 rear wheels). Here's an easy way to remember: It's the width of the "track" left by the vehicle when traveling forward in a straight line.
That is what I used.
Unread 26-11-2014, 12:00
dellagd's Avatar
AKA: Griffin D
Re: Physics Quiz 10
Ah, well even if I did find out the dimensions correctly I must have set up the proportion between the carpets velocity and the robot's orientation inversely. The solution below works out, so unless a mathematical equality that makes this give the right answer for the wrong reason is working here and I haven't realized what it is, I must have accidentally flipped that value somehow. It was late, I probably used the wrong angle for being tangential to the robots rotation which lead me to the wrong proportion.
Updated solution:
Spoiler for Solution:
2 + Vcy = Fy
Vcx = Fx
Fy/Fx = -2 / (28/12) #Known angle of vector sum/friction
Vcx/Vcy = 2 / (28/12) #Known angle of carpet velocity
Substitute in for Vcx and Fx:
2 + Vcy = Fy
(2 / (28/12)) * Vcy = (-(28/12) / 2) * Fy
Substitute in for Fy:
2 + Vcy = ((-2^2)/((28/12)^2)) * Vcy
Vcy = -1.153
Into another equation:
Vcx/(-1.153) = 2 / (28/12)
Vcx = -.988
Robot Velocity components are opposite of these.
Vry = 1.153
Vrx = .988
Vr = sqrt(1.153^2 + .988^2) = 1.519 ft/s
Vtangential = r * omega
r = d/2 = sqrt(2^2 + (28/12)^2)/2 = 1.537 ft
omega = Vt / r = 1.519 / 1.537 = 84/85 = .988 rad/s
I confirmed this using the other method and my answer was the same down to 6 decimal places.
Unread 26-11-2014, 19:00
Re: Physics Quiz 10
Physics Quiz 10 part C:
Given:
- wheelbase=24 inches, trackwidth=30 inches
- center of mass 150lb located 3 inches forward and 4 inches to the right of the center of geometry
- assume flat level floor, and the bottom of all four wheels coplanar
Find the weight (normal force) at each wheel.
Unread 26-11-2014, 19:34
Jared's Avatar
Jared Jared is offline
Re: Physics Quiz 10
Given:
Front left 34.375
Front right 59.375
Back left 20.625
Back right 35.625
Work:
http://i.imgur.com/MQ0xHY7.jpg
Unread 26-11-2014, 19:37
Re: Physics Quiz 10
Front left 34.375
Front right 59.375
Back left 20.625
Back right 35.625
Work:
Reps to you !
Unread 26-11-2014, 20:03
Re: Physics Quiz 10
Physics Quiz 10 part D:
Assume the following:
- skid-steer vehicle with 4 standard non-treaded wheels, except the 2 front wheels are badly misaligned:
--- FrontRight is 0.22983514251446 radians CCW
--- FrontLeft is 0.65426122466113 radians CW
- coefficient of kinetic friction 0.7, independent of speed and direction
- left wheels being driven forward at tangential speed 2 ft/sec
- right wheels being driven backward at tangential speed 2 ft/sec
- at steady state, the vehicle's center of rotation is located at the center of mass
At steady state, how fast is the robot rotating?
Unread 26-11-2014, 20:50
Jared's Avatar
Re: Physics Quiz 10
This one is trickier...
Im not sure if this is right, especially because the robot must now be constrained to rotate around its center, but I got 0.1748 rotations per second = 1.098 rad/sec.
Work:
Unread 26-11-2014, 21:28
Re: Physics Quiz 10
Yes it is. But this is all leading somewhere, and we're almost there.
Work:
There was no link to your work.
Here's how you can check your answer:
1) at each wheel, use your answer to calculate the carpet velocity vector at that wheel due to robot rotation around the center of mass
2) at each wheel, combine (vector addition) the carpet velocity due to robot motion at that wheel (from step1) and the tangential velocity of that wheel to get the net carpet velocity at that wheel.
3) compute the normal force at each wheel, and use that to calculate the magnitude of the kinetic friction at each wheel.
4) at each wheel, use the net carpet velocity direction (from step2) at that wheel to split the kinetic friction magnitude at that wheel into X and Y components at that wheel
5) Sum the X components from step4. The sum should be zero at steady state.
6) Sum the Y components from step4. The sum should be zero at steady state.
7) Sum the torques around the center of mass due to the X and Y components from step4. The sum should be zero at steady state.
8) If any of the sums from steps 5, 6, or 7 are not zero, your answer is not correct.
Unread 26-11-2014, 21:43
Jared's Avatar
Re: Physics Quiz 10
I think now that my answer is wrong because I must have a net force in the x direction due to friction. For my answer I had used my previous method of breaking the velocity into two perpendicular components, with one of those components tangent to the circle centered at the robots center and intersecting the wheel.
I then multiplied each of these velocities by the ratio of weight over the wheel to total weight so that the wheel closer to the center of mass and with the most weight on top of it have a greater impact on total velocity.
To me, this seems like you might be leading Us toward forward kinematics for swerve...
Unread 27-11-2014, 10:39
Re: Physics Quiz 10
Notice that you can use the above to find the answer.
Set up equations using steps 1 thru 7, then plot 5, 6, and 7 vs omega and locate the value of omega for which all 3 curves are zero.
Reps to the first person to post a graph with the answer (show your work).
Unread 30-11-2014, 15:06
Re: Physics Quiz 10
Here's how you can check your answer...
This thread keeps getting hits so maybe there's still some interest.
I'll kick-start this, with Step#1 for the Front Right wheel:
> # rad/sec robot rotation around CoM:
> omega=1.098
      1.098
> # wheelbase:
> L=24/12
> # trackwidth:
> W=30/12
        2.5
> # X coordinate of Center of Mass (relative to Center of Geometry):
> Xm=4/12
 0.33333333
> # Y coordinate of Center of Mass (relative to Center of Geometry):
> Ym=3/12
       0.25
> # X component of carpet motion at FrontRight wheel due to robot rotation:
> V1x=-omega*(L/2-Ym)
    -0.8235
> # Y component of carpet motion at FrontRight wheel due to robot rotation:
> V1y=omega*(W/2-Xm)
     1.0065
Unread 04-12-2014, 17:29
Re: Physics Quiz 10
Steps 1 & 2 for front right wheel.
