Go to Post Interestingly enough, I saw Shaun open his backpack for a moment during the Newton Alliance selection.... 4 Hours later Team 25 was on Einstein... - thefro526 [more]
Unread 26-11-2014, 22:08
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: pic: 8WD LARGE BORE BEARING WHEEL SYSTEM
Originally Posted by Kevin Ainsworth View Post
large bore bearings are used to reduce rolling resistance
For my curiosity, can you explain the reason behind this? Is it something to do with a larger shaft/bore surface area to spread the load over, or more rolling elements in the bearing, or something else?
Thanks,
FRC 766, 2015-, Mentor
