Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Unread 26-11-2014, 23:34
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: pic: 8WD LARGE BORE BEARING WHEEL SYSTEM
Originally Posted by Kevin Ainsworth View Post
42mm OD/30mm ID large bore bearings are used to reduce rolling resistance
Do you have an estimate of how much?
