Go to Post HOLY MOLY CANOLI THIS LOOKS LEGIT - MasterEric [more]
Unread 26-11-2014, 22:05
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
pic: 8WD LARGE BORE BEARING WHEEL SYSTEM
Unread 26-11-2014, 22:08
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: pic: 8WD LARGE BORE BEARING WHEEL SYSTEM
Originally Posted by Kevin Ainsworth View Post
large bore bearings are used to reduce rolling resistance
For my curiosity, can you explain the reason behind this? Is it something to do with a larger shaft/bore surface area to spread the load over, or more rolling elements in the bearing, or something else?
Thanks,
FRC 766, 2015-, Mentor
Unread 26-11-2014, 22:30
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
I imagine it has a lot to do with maintenance as well. The wheel, shaft, and spacers are all one part now. Not to mention, it looks incredible.
This is so cool.
Unread 26-11-2014, 23:34
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
42mm OD/30mm ID large bore bearings are used to reduce rolling resistance
Do you have an estimate of how much?
Unread 27-11-2014, 00:28
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I'm curious why you decided to make the end of the shaft bore a hemisphere as opposed to a flat-ish end.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 27-11-2014, 03:05
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
How does having the wheel like this improve maintenance over the current WCD set up?
