#61
Re: One speed vs Two speed gearboxes
Our experience at work with using the NP7-12's in our UPS' is that applications that cycles the batteries more frequently and discharge them more deeply will shorten the life of the batteries, dramatically. There is also a line that states "When considering discharge currents exceeding 6C, consult with an EnerSys Application Engineer." Notes from manufacturers like this usually indicate that their experience is that such operating conditions are likely to permanently damage or shorten the life of the component. The 6C discharge rate corresponds to 103A which is easily exceeded in many of the recent drive train designs. www.enersys.com/WorkArea/DownloadAsset.aspx?id=489 |
#62
Acceleration isn't the only benefit. 6 cim drives are more efficient as they operate higher on the motor efficiency curve.
#63
With a simulation model. As you add more cims, the torque load (and current) is split to more motors. Map this new torque on the cim motor curve, and you will see the motors spin at a higher speed creating more mechanical power. This is most noticable during times of high load such as turning and pushing where you operate closer to peak power instead of peak efficiency.
#65
All else being equal, the CIMs on a 4 CIM drive spin the same speed as the CIMs on a 6 CIM drive, for any given robot speed (assuming the wheels are not slipping).
#66
I don't think they will consume the same eletrical power though. |
#67
When accelerating, the 6 cim will draw more power, but it will reach the constant velocity situation faster, when it will start drawing less current. |
#69
The 4 cim system takes the same amperage, but more voltage to reach that amperage. So the 4 cim system does use more power to hold an identical velocity.
#71
That doesn't make sense. It should take more amps than a six cim system per motor. Adding all the motors, a four cim system should use the same number of amps as a six cim system, with a bit of wiggle due to the efficiency curve of the cim.
#72
Thats only 900w. So less power is used by the 6 cim system to hold the same speed. |
#73
I would argue that for a significant number of teams an increase in top speed results in a less competitive robot because their drivers won't be able to handle the "twitchier" controls. I think slowing down the kit gearbox is one of the easiest knobs FIRST has to increase match scores, because it should be easier for good robots to get around the D and teams with less good mechanisms will have an easier time scoring. If I had a nickel for every time I watched a robot spend 2 minutes to pick up a game piece...
#74
It's straightforward to do the calculation. Let's pick an operating point, say 2000 rpm at 240 ozin total torque of CIMs. Calculate the CIM operating condition at 2000 rpm and 60 ozin (for 4CIM drive), and 2000 rpm and 40 ozin (for 6CIM drive): Code:
Motor Calculator build MCALC_2014d 2/3/2014 1255pm Enter rpm and ozin, separated by a space: 2000 60 CIM @ 6.62 volts: oz-in Nm rpm rpm% amps watts out watts heat eff% 60.0 0.424 2000 68.3 24.3 88.7 71.7 55.3 Enter rpm and ozin, separated by a space: 2000 40 CIM @ 5.92 volts: oz-in Nm rpm rpm% amps watts out watts heat eff% 40.0 0.282 2000 76.4 16.5 59.2 38.5 60.6 6 CIM mechanical watts out = 6*59.2 = 355 watts 4 CIM amps total = 4*24.3 = 97.2 amps 6 CIM amps total = 6*16.5 = 99.0 amps 4 CIM electrical power in = 6.62*97.2 = 643 watts 6 CIM electrical power in = 5.92*99.0 = 586 watts So under certain operating conditions (in this case, 2000 rpm @ 355 watts out), 6 CIM draws less total power. Last edited by Ether : 28-11-2014 at 18:09. |
#75
So we've been thinking about auto-shifting some more, and how to increase our efficiency. I've also heard that 1678 achieved speeds of 22 ft/s on the field and wondered how they did that, especially if they started in first gear then shifted or if they were in 2nd the entire time (assuming they used shifters). We were happy with our auto-shifting system last year and would like to improve it further. This led to a few questions:
How do we figure out the correct gearing for the low gear supposing we know we want to have a high gear of 17 ft/s? This needs to maximize acceleration as well as battery life. What exactly does it mean to be traction-limited and what are the physics equations and calculations surrounding that? We are planning on using either 4 CIMs, 4 CIMs and 2 MiniCIMs, or straight up 6 CIMs, so any advice on those configurations would help as well. I didn't want to start a new thread since there has been so much discussion on the topic, but since using auto-shifting as a method of avoiding blowing the main breaker was discussed here, I figured it was apt. We didn't have to worry about that last year since we only had 4 CIMs on the main drivetrain. |
