Go to Post One transmission to rule them all, one transmission to bind them... :p - artdutra04 [more]
Unread 28-11-2014, 19:53
Programator's Avatar
Programator Programator is offline
Programator is an unknown quantity at this point
FLL proportional alignment!
Could someone please help me on making a proportional alignment program with an EV3?
Thank you!
Unread 28-11-2014, 20:02
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: FLL proportional alignment!
Can you explain what you mean by "proportional alignment"? What do you want the program to do?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 28-11-2014, 23:22
Sorry I did not specify, what the program is supposed to do is align on a colored line with light intensity while using a proportional controller.
Thank You
Unread 29-11-2014, 17:02
DonRotolo's Avatar
Back to humble
FRC #0832
Find the white paper here on CD somewhere called "PID without a PhD", that will help you understand the idea behind a P controller. Then search the term "PID" which is what you are looking for - just that your I and D terms will be ignored.
I'm not a programmer, and i know little about the EV3, but...
<Pseudocode>
Does sensor see line?
   Yes: Move forward a little
   No: Turn a little
repeat until you reach 'goal'
Unread 29-11-2014, 23:46
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We didn't have a LEGO team this year, but last year we had a couple of PID "P" only drives. Attached are a few "test" samples that run in a loop for testing and tuning.
#1: LightDrive: This followed a black line with pin point precision. You're light sensor needs to be about 1/2" to 3/4" away from the line.
#2: GyroDrive: We could drive in a straight line using the Gyro.
Hope it helps.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 30-11-2014, 21:19
Could someone please post a link to "PID without a PHD".
Thanks!
Unread 30-11-2014, 21:21
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Here you go
http://www.embedded.com/design/proto...-without-a-PhD
