Go to Post I think applying Gracious Professionalism to strictly legal game play trivializes what is a much more important and fundamental FIRST concept. - jimfortytwo [more]
Unread 30-11-2014, 01:31
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
pic: Finally Done!
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: pic: Finally Done!
I think it might be a smart idea to 3D print the side plates, that way you don't have to use all your grant money machining something that might not work
Unread 30-11-2014, 01:36
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Smart idea.
...in other news, this is really cool! Looks similar to some designs that Bryce2471 has posted in the past.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 30-11-2014, 01:49
Originally Posted by Jacob Bendicksen View Post
Smart idea.
ONLY if you do the math for the 3d print.
Remember, folks, 3D printing can be plenty strong, but if you 3D print plastic sideplates for gearboxes without redesigning from a design made for metal, you're probably going to shoot yourself in the foot. Gearboxes with plastic sideplates are few and far between as it is due to durability concerns. Now you're adding in that the sideplates would have a built-in weakness--the layer boundaries--and that they're not going to be all that filled in... I'd make sure to run the numbers prior to attempting a 3D print.
Unread 30-11-2014, 04:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I highly recommend against this.
3D printing does not hold the required tolerances for work such as bevel gears, particularly plastic 3D extruders. The printers normally found in FRC are NOT suitable for work such as this, plus they have a "step" of 0.003" vertically; you will end up with a lot of slop in your gear train. You have to double or triple stack the tolerances due to the existence of side plates.
Not to mention press fits with bearings is barely possible, as a decent press fit in plastic may weaken or destroy the frame during pressing due to the layering (depending on the printer).
Plus, you still have to do heavily loaded tests to make sure that it can hold up due to the plastic and layering.
Now, some actual questions:
1. What is the final weight of this gearbox without motors?
2. What is your reasoning for going with a bevel gear setup?
3. What advantages does this design hold over 192's gearbox design from 2014? I still haven't seen a shifting gearbox design that beats theirs in terms of weight or size.
20fps is too fast. You can limit the top speed in software for the driver, but your acceleration will be very poor with only 4 cims. Seeing as you are running bevel gears, would it be possible to add a 3rd cim sticking stright up?
Your final gear reduction looks like it can be reduced to a much smaller/better ratio. Top speed for a 4 cim drive shouldn't hit above 17-18fps if you want to optimize distance/time. OC it depends on the game, but it would be a very rare game that requires 20fps on four cims.
Unread 30-11-2014, 12:10
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
I like the idea of 3-D printing the plates. I don't know why everybody is so against it, last year we (1885) used 3D printed parts to join an axle for our intake, it worked very well and only "broke" when we didn't check it and a shaft collar was loose. Then the axle would fall off and we would have tighten the collar up again.
Just use a high quality plastic and use a dense pattern while printing AND MAKE EXTRA'S!!!!! Better to get into 3D printing now while it is still being developed heavily, we all know it will only become more and more common, so this is a great foundation to build off of in the future.
Alumni from 75 and 1885
Unread 30-11-2014, 12:24
If they were using metal 3D printing, I think most people wouldn't bat an eye. The problem is that those machines are generally 6-7 figures, not counting material, and most schools won't go for that.
Now, note this, I'm not against 3D printing, or even necessarily against 3D printing gearbox plates. I'm against 3D printing gearbox plates WITHOUT accounting for all the stresses and loads in the design, and "just because it's the next thing". If you think the plates should be 3D printed, please, by all means, print a set of plates for a given gearbox--just make sure to document the process and the failure.
A coupler sees very different stresses from a gearbox sideplate. I've seen 'em used in very high-load applications when 3D printed, but as I recall that particular coupler broke about a month after it entered service, due to a combination of factors that were not necessarily directly related to the loads it was seeing, and was replaced by a machined part.
Now, in case you need help reading a block of text, here's a list of reasons not to print the plates:
  • 3D printing can't hold as tight of a tolerance as machining, and tight tolerances are REQUIRED in gearboxes.
  • The printer prints in layers. If you orient them right, you can get away with the built-in failure modes this creates. Otherwise, ouch.
  • Press-fits can damage the plates. What exactly is press-fit? Only about every bearing in the gearbox!
  • If extra spacers will cause an issue, you don't want to print, because the screws to hold the gearbox together will need washers, which will act as spacers.
tl;dr: I wouldn't 3D print a gearbox plate unless I had specifically designed the gearbox for 3D printed plates, and specifically designed the plates to be 3D printed. This gearbox is, as far as I know, NOT designed for 3D printing. Therefore, it is a very BAD idea to 3D print this gearbox.
Unread 30-11-2014, 12:30
Jared's Avatar
Jared Jared is offline
What you have described to join an axle isn't the same as gearbox plates.
Gears (especially bevel gears) require very accurate positioning. If the gears are to close together, or the shafts aren't parallel, the gears wear much, much faster. Team 254 made some delrin side plates a long while ago and one of their mentors said that the flexibility of the plastic didn't keep the gears well aligned. The thrust loads from the bevel gears will only worsen the problem of the deforming side plates. Also, you can't really get a press fit for the bearing with a 3d printer. First of all, the printer isn't accurate enough to get the right size hole, and secondly, the plastic has a high chance of cracking if you try to press in a bearing.
The side plates can be made on a mill and a bandsaw. The outer profile doesn't need to be accurate, so you could just print and cut out out a correctly scaled drawing, and trace it with sharpie on a piece of 0.25" thick aluminum to cut on the bandsaw. The mounting holes/bearing bores should be fairly easy to do on a mill.
Personally, I wouldn't go with the ratios you have chosen for your shifter. I'd recommend using smaller wheels, or adding an extra stage of chain reduction first. 9 feet per second with 4 CIMs in low gear is on the fast side, and you'll experience breaker tripping in low gear. Also, 20 feet per second with 4 CIMs will have very poor acceleration, and will really wear down your batteries quickly.
Which bevel gears are you using?
Unread 30-11-2014, 12:43
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Using 3D printed plates instead of metal is somewhat like using zip tie instead of steel wire. Zip tie is nice, you can quickly fasten most things and reasonably strong, but if some applications will have so much dynamic forces they will just get ripped.
Using 3D parts for lighter loads as in to feed a ball is different than gear box or any structural parts in a drive system.
May be just for prototyping and quick test it may be ok, but for competition robot... its not just worth the risk.
Unread 30-11-2014, 12:54
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I like the gearbox-- it looks like some nice work. I'll add my voice to the people that would recommend against printing this for actual use on a robot-- I think the others have done a pretty good job of explaining why that's a bad idea. I can say firmly from experience that it isn't nearly as good an idea as it first seems.
That being said, printing certainly has its place in the design of an all-metal gearbox if you want it to. Last year I had a decent amount of success doing a high shell count and drilling/reaming essential holes, and it's always nice to test the geometry in practice as well. With a little bit of adjustment and a small amount of work, you could probably do a manually powered version to print and test before you made a metal version. I'm not entirely sure how beneficial that would be, but it would certainly be cool/interesting to show off.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-11-2014, 12:58
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Alternatively, you mention that you're getting an inhouse mill in your first post. Do pre-season testing on a variant without all the fancy lightening and contouring, and then use your external resources and funds to do the full, lightened version for the season.
Unread 30-11-2014, 13:01
That's got me curious--what happened? Got any pictures (or videos)?
Unread 30-11-2014, 14:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This argument shouldn't be about why to 3D print/not 3D print...it should be about why this design is a good use of resources to make at all.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-11-2014, 14:38
Jared's Avatar
This is an excellent point to consider. In my opinion, a custom gearbox isn't worth the trouble unless you're sure it'll work, you're sure you can make it, and it'll be superior to an off the shelf gearbox in some way.
This gearbox likely won't be cheaper than an off the shelf wcp ds or ball shifter gearbox, but it doesn't hang low to the ground, and I'd bet you could direct drive a 3.25" wheel with the gearbox, something that can't be said about most off-the-shelf gearboxes. Its unique shape also frees up the space where motors would normally go in a typical configuration
If you think that this is the best way to improve your team's robot (this totally depends on your team's unique situation), then it's a great idea to try to build one in the offseason first.
Unread 30-11-2014, 14:57
Originally Posted by Dr.Gusta View Post
...bevel...
Is the bevel on the pinion? Are the CIM shaft bearings rated for the thrust load that would create?
