Go to Post If you're in the Chairman's Award just to win the Chairman's Award, you're doing it for all the wrong reasons. The award is there as a goal to strive for, but it shouldn't be the reason why you conduct yourself and reach out to your community and beyond the way you do. - Lil' Lavery [more]
Unread 30-11-2014, 15:49
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: pic: Finally Done!
Curious about the questions above.
And,
How you're dealing with the thrust loads from the bevel gear and pinion? If they gear isn't supported with thrust bearings you'll probably destroy the radial bearings you're using.
The cim shafts can move a bit in and out, do you have a way of making sure the pinion is in the correct place?
