Go to Post The animation is just a pretty tool to help outsiders understand the game; the manual is for me, the animation is for my grandmother. - JVN [more]
Unread 30-11-2014, 13:55
daniel12997's Avatar
daniel12997 daniel12997 is offline
Student
AKA: Daniel Parker
FRC #1736 (Robot Casserole)
Team Role: Student
daniel12997 is an unknown quantity at this point
Pneumatic Muscles
So, I have had robotics on my mind a lot recently, and I was just wondering could you use air pressure and pneumatic tubing to make pneumatic muscles? If so how feasible they would be, and what would be some possible uses for them?
Thanks for any comments
-Daniel
Unread 30-11-2014, 14:16
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Pneumatic Muscles
I recall FIRST choice having a variant of these available a few years back.
I don't think they saw much use.
Unread 30-11-2014, 15:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
"Pneumatic muscle" is just a cylinder right? Contract/extend? A cylinder should act like a pair of- I think the term is complementary? -muscles. And pneumatics have a lot of uses.
How many compressors can we have on a bot?
Unread 30-11-2014, 16:11
NWalker's Avatar
NWalker NWalker is offline
NWalker
FRC #1619 (Up-A-Creek Robotics)
Team Role: Electrical
NWalker can only hope to improve
As far as a contract-extend pneumatic cylinder goes, we (1619) used a few this year to make a hinging claw to pick up the ball. What would happen is the claw would open, swing forward, scoop up the ball, close, and retract back up with the ball. I am new to the team this year, so I don't know the details of placement and such, but that was the basic premise.
Unread 30-11-2014, 16:22
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Definitely one compressor (obligatory we-dont-know-next-year's-rules-for-certain) See 2014 4.10 R79
On a technicality, muscles only "retract" and relax, offering little/no force in the "pushing" or extension direction. It takes a pair of muscles pulling on opposite sides of a joint to fully operate the joint.
A double acting, and to an extent, a single acting cylinder offers force in both the extending and retracting directions.
If you are referring to something similar to what Joe posted, I would make the point that there is (in FRC applications) very very little that that device could do that a standard cylinder could not.
By simply looking at the picture,
It seems lighter due to its not steel construction, and more lenient in handling non-coaxial forces.
Unread 01-12-2014, 09:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
While the function is similar, a pneumatic muscle is different than a cylinder. FRC has been very restrictive on the list of the components allowed in the past. The tubing allowed would not make a good muscle since it doesn't contract that much with the allowed pressure. There was the First choice part a couple of years ago.
Unread 01-12-2014, 11:14
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
We have a pneumatic muscle, and I have to say, I can't think of a single use for it that a cylinder wouldn't do 10x better in FRC. It has a very short and weak retract rate, and compared to a cylinder, takes a lot more effort to mount as the fittings are on either end. Additionally, the activation time is significantly longer than a piston. It is much simpler to just get a cylinder, and given the throw of the muscle, a cylinder of that size is likely lighter.
Unread 29-12-2014, 11:33
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
A pneumatic muscle is good in tension. Like the muscles in your body it cannot "push". You need a spring, gravity or a 2nd muscle to pull in the opposite direction. They are very durable and have no sliding seals to leak. Traditional cylinders are somewhat delicate, especially long stroke cylinders in the extended position. Pneumatic muscles don't have much stroke (only 25% of it's overall length) but can pull with a lot of force. For example a 20mm diameter actuator can lift 230 lbs at 60 psi. A 20mm traditional cylinder can only lift about 29 lbs.
They aren't simple rubber tubes. Then have diagonal tensile members that can't stretch. So when the diameter of the rubber sleeve increases due to increased air pressure, the length must shrink. Check out this cool Festo humanoid video.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 29-12-2014, 15:55
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Team 1699 has one lying around the shop. I have been bugging mentors for the past year or 2 to try and use them. When just messing around I couldn't get the festo ones to work. They are really helpful though. They weight practically nothing compared to regular actuators and are super strong. You can also vary their length. They aren't just fully retracted or fully extended. Im still trying to get these to work.
Unread 30-12-2014, 13:51
AKA: Kevin Thorp
You wrote "Im still trying to get these to work". What problem are you having?
Summerville, SC USA
Unread 30-12-2014, 14:41
FRC #1991 (Dragons)
We were having trouble getting them to retract. But that was during build season and was probably some stupid little thing I missed because I was working on 5 other things at the same time. Sadly our team does little to no off season work to get time to play with them some more
