Go to Post We really are nerds, aren't we? - Eria4044 [more]
Unread 27-11-2014, 14:31
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
pic: 8WD CONCEPT DRIVETRAIN
Unread 27-11-2014, 14:33
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: pic: 8WD CONCEPT DRIVETRAIN
I am curious to what advantage was found by raising the front wheels 1/4". Most 8 wheel drives seem to have the center 4 wheels dropped between 1/8" to 1/4"
Unread 27-11-2014, 19:59
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Is it just me, or are you using chain for an encoder on your gearbox?
If so, could you shed some light on why this was chosen, and how it will work?
Thanks
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 28-11-2014, 02:07
Knufire Knufire is offline
If I remember correctly from talking to Nick Coussins, it's plastic VEX chain.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 28-11-2014, 02:45
Team Captain
If it does use chain, plastic or metal, then I strongly feel gears would be far more reliable and easier to work with
Unread 28-11-2014, 03:10
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Or a mounting the encoder to one of the wheel axles like most other WCD teams.
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 28-11-2014, 19:13
daniel12997's Avatar
daniel12997 daniel12997 is offline
Student
AKA: Daniel Parker
FRC #1736 (Robot Casserole)
Team Role: Student
daniel12997 is an unknown quantity at this point
It makes turning easier because then the wheels don't drag
Unread 28-11-2014, 21:42
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
True, but traditionally 8WD setups have raised both the front and rear set of wheels to shorten the wheelbase length to promote turning.
With the shorter robots, it's possible to drive 6wd without a drop center fairly smoothly. With the further shortened wheelbase provided by the front wheel being raised, I'd imagine it's pretty easy to drive the other 6 wheels...... Although I'm still not sure exactly why they chose 8wd with only a single set of wheels raised.
(2015-?): 973
(2012-2015): 955
Unread 28-11-2014, 22:49
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Well, I would just 3D print some gears for the encoder myself. Maybe they have some other reason to go with chain.
Unread 29-11-2014, 00:24
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Depending on where your center of gravity ends up on the final robot, you can adjust which wheels you raise/drop and by how much, because your frictional/scrub force will be greater in the areas close to the CoG. All about the weight distribution.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 29-11-2014, 00:51
Pumped
AKA: Ryan
My guess is it has more to do with the tilt/COM change that robots undergo when they are changing velocity and direction, rather than weight distribution and wheel friction.
(2015-?): 973
(2012-2015): 955
Unread 29-11-2014, 03:56
Team Captain
It seems they were planning more for higher speeds and accelerations rather than maneuverability. I feel that having only the front wheels raised gives the robot better tracking. However, I still think an 8WD with the 4 center wheels dropped is better because you are still going to get 6 wheels of contact (when moving or acceleration or whatever) and also get the maneuverability
Unread 29-11-2014, 16:53
Pumped
AKA: Ryan
You only get 4 wheels touching the ground at any given time with an 8wd
(2015-?): 973
(2012-2015): 955
Unread 01-12-2014, 12:11
FRC #2451 (Pwnage)
Two topics:
1) Encoder Vex Chain
I don't really like this myself but we haven't had time to change it. It should work but could be a pain. Any slop would result in inaccurate positioning for low speed maneuvers. I personally would like to see gears, thanks for the input.
2) 8WD Chassis Wheel Lift
We ran the same configuration in 2013 and the thing was a beast. Where your center of gravity is positioned does matter. You would ideally want it to be located central to the six wheels touching the ground, so between the gearboxes. If you made the front and back wheels both raised your robot would be tipping forward and backwards every time you accelerated or decelerated. It would also make your robot unstable during dynamic moves. It would make your contact patch width to length ratio way to high and your robot would be extremely unstable and twitchy at speed. Your width would be about 28" and length would be around 9" so your ratio would be 3:1. Way too high. We modified our 2013 practice robot to test the ideal ratio by making the side rails slide in and out on extrusion and I can tell you the current ratio is about ideal for high speed stability and low speed maneuverability. There was no perfect ratio but too long and it took too much motor energy to overcome the scrubbing wheels, too wide and it became too twitchy. I would like to know what Team 67 had on their wide 2012 robot. From their tech notes it looks like none of the wheels were raised but that's from looking at the pixelated AutoCad drawing. I can tell you from actual testing that with six wheels touching we can go full speed, throw one stick the opposite direction and pinwheel to go the opposite direction, at full speed. I see no issues with maneuverability, low speed scrub is minimal and it doesn't take much power at all to pinwheel with no forward motion. The wheel contact patch is still wider than it is long so you get the best of both worlds.
Unread 01-12-2014, 12:17
FRC #2451 (Pwnage)
https://drive.google.com/file/d/0B67...ew?usp=sharing
CAD can be found here if anyone's interested.
