Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 01-12-2014, 19:11
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Re: pic: 8WD CONCEPT DRIVETRAIN
Originally Posted by Kevin Ainsworth View Post
Two topics:
1) Encoder Vex Chain
I don't really like this myself but we haven't had time to change it. It should work but could be a pain. Any slop would result in inaccurate positioning for low speed maneuvers. I personally would like to see gears, thanks for the input.
2) 8WD Chassis Wheel Lift
We ran the same configuration in 2013 and the thing was a beast. Where your center of gravity is positioned does matter. You would ideally want it to be located central to the six wheels touching the ground, so between the gearboxes. If you made the front and back wheels both raised your robot would be tipping forward and backwards every time you accelerated or decelerated. It would also make your robot unstable during dynamic moves. It would make your contact patch width to length ratio way to high and your robot would be extremely unstable and twitchy at speed. Your width would be about 28" and length would be around 9" so your ratio would be 3:1. Way too high. We modified our 2013 practice robot to test the ideal ratio by making the side rails slide in and out on extrusion and I can tell you the current ratio is about ideal for high speed stability and low speed maneuverability. There was no perfect ratio but too long and it took too much motor energy to overcome the scrubbing wheels, too wide and it became too twitchy. I would like to know what Team 67 had on their wide 2012 robot. From their tech notes it looks like none of the wheels were raised but that's from looking at the pixelated AutoCad drawing. I can tell you from actual testing that with six wheels touching we can go full speed, throw one stick the opposite direction and pinwheel to go the opposite direction, at full speed. I see no issues with maneuverability, low speed scrub is minimal and it doesn't take much power at all to pinwheel with no forward motion. The wheel contact patch is still wider than it is long so you get the best of both worlds.
That's what I was thinking, so the raised set is just there to prevent the robot tipping.
(2015-?): 973
(2012-2015): 955
Unread 02-12-2014, 18:16
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
I like the idea of using larger bearings and shafts to minimize losses, but I'm curious how much of a difference it would actually make.
I could be wrong, but it looks like the rational behind this design is higher efficiency by eliminating any losses from the standard hex shaft approach.
On a standard WCD, there is no space between the wheel and the bearing. So the bending of the shaft is almost nonexistent. Because of this I think your bearing setup will make very negligible difference.
Last season during a meeting in which we discussed what we wanted to accomplish with our off season drive train design, a very respected mentor offered a great piece of advice. That advice was to go after low hanging fruit. This means to go after the small problems that can be easily solved, and as many as you can. I say this because I think you're tackling a very small and possibly nonexistent problem with a solution that demands a lot of resources. I think those resources could be better spent, a lot could be accomplished in the time it takes to design and fabricate your bearing configuration. My suggestion is to identify that low hanging fruit, and to allocate your resources accordingly. In my eyes it's better to tackle several small problems that fix one with a complex solution.
This is just my 2 cents. All that being said, kudos to all involved in this design. You guys identified a problem and came up with a very elegant solution.
Best of luck rumbling in 2015's ultimate assist
-Adrian
