Go to Post Even at Mc Donalds, dinner with Dean would be really cool! - Josh Hambright [more]
Unread 01-12-2014, 23:46
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Ball Shifter High Gear Issues
Originally Posted by asid61 View Post
12.6fps free speed for high gear is nowhere near the max speed for a 4 cim setup. We ran 15fps on 4 cims easily last year, and bumped it up to 17fps later with no problems (at least not on the gearbox side).
Are your c-c distances correct on the gears? The situations you describe are high-torque situations, and the ratcheting sound might be gears slipping. Get out some calipers and measure the c-c distance. Also, try running it without load and see if the issue persists.
That's what I figured. It would really be nice to have a solid 14ish fps high option. I have not measured it but it is a COTS gearbox so unless something is seriously wrong I don't think it would be the c-c. With no load there is no noise. Thank you for the suggestions.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 01-12-2014, 23:54
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We had ratcheting noise on our 14U last season, found some pulleys were cracked. Doesn't explain all your symptoms though.
Unread 02-12-2014, 03:14
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I can almost guarantee that you are experiencing a worn out shifting shaft/plunger.
When you were geared so low all season, I assume that you usually used high gear, which means that the shaft was consistently exposed to large compressing forces that deformed it. You probably didn't notice the damage because not a lot of input torque was required to drive around with such a slow gear ratio. After all, you had low gear for the heavy stuff.
When you switched to the taller ratio, there was an increase in load that made the ratcheting start. The part I am referring to is made out of aluminum, and vex may be changing it to steel for future years.
There is a possibility that i got this wrong though. You can confirm my theory by disassembling the gearbox, but that's a pain...
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 02-12-2014, 03:19
Lead Bumper Mentor
AKA: Mike Marandola
Thanks for the suggestion. We recently disassembled them since we suspected the issue to be wear on the plunger or gears but that was not the case. Also, I believe the majority of the force is put on the ball carrier, which is why it's steel.
Unread 02-12-2014, 09:34
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
I would suggest checking the distance that the shifter is pulled toward the cylinder to get to the correct part of the plunger. If it is on the edge if the hump in it it is prying the cylinder out of gear. We had this issue several times from the coupler coming loss through the season.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 02-12-2014, 09:50
Are you saying that you found the problem but it was not where expected?
Or are you saying that you found no evidence of damage or wear on any of the parts? Did you inspect them with strong light and adequate magnification?
