Go to Post CD makes FIRST an infinitely better place. - lemiant [more]
Unread 02-12-2014, 00:28
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Center Wheel Drop?
I have almost finished CAD for my teams drive base and have been able to figure out everything out from other CD posts but I put a 3/16th inch center wheel drop. As I finish up CAD I am starting to question my self that is too much of a drop. Just so you know it is a 4in wheel with a ball shifter geared for 17.1fps High and 7.54fps Low. It is also a 6 wheel drive tank drive.
Unread 02-12-2014, 00:35
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Center Wheel Drop?
What is your wheelbase and type of wheel? Also how are you measuring your drop?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 02-12-2014, 00:45
Dr.Gusta's Avatar
Team Role: CAD
We are using the AndyMark 4in high grip wheels http://www.andymark.com/product-p/am-2256.htm
Drive Base is 25in wide x 30in long
Taking the center of the wheel and moving it down 3/16in
Unread 02-12-2014, 00:55
Lead Bumper Mentor
AKA: Mike Marandola
The HiGrips are smooth enough that you could go down to 1/8" for a long configuration or even less for a wide configuration.
Unread 02-12-2014, 08:41
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Yup, I think it mainly has to do with the type of wheels. If you use something a little more rough like blue nitrile, you'll probably need something like 3/16th. But I think 1/8 should work for those wheels that you're using.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 02-12-2014, 10:09
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
3/16" may be a little too much, with 1/8" drop it gets a bit horsy...wobbles a bit too much, this is what we have experienced.
Unread 02-12-2014, 11:01
Jared Russell's Avatar
Taking a year (mostly) off
The right answer is a function of many things. How stiff is your robot frame? Stiffer frames can get away with less drop. How high is the center of mass? A high CoM exacerbates rock when accelerating or decelerating. How willing are you to frequently replace wheels/tread? The middle wheel generally wears quickest, reducing the effective drop over time. Being proactive about replacing it (or rotating wheels) lets you get away with less drop. Driver preference also plays a role in this. A little bit of scrub is helpful for tracking straight and for doing controlled turns, while more rock makes the robot drive more smoothly (but requires greater driver skill or software help to control).
Some of these factors are difficult to estimate beforehand. As a general rule, especially with the smaller robots used the past two seasons, most teams will be happy with 1/8" of drop.
Unread 02-12-2014, 11:03
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
1/8 inch is not enough drop. The robot sinks into the carpet about that much. The high-grip wheels also wear like crazy and the center wheel wears more. With 1/8 inch drop you'll eventually have no drop at all.
3/16 might be a bit too much, .150 is the number I always use.
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 02-12-2014, 11:39
Michael Hill's Avatar
Michael Hill Michael Hill is online now
I'll echo this.
We just did our first 6-wheel drive last year and did a 5/32" drop. It worked out pretty well for us, but there was a little more rock then we liked initially, especially when we used the W-tread. When we switched to rough top, it felt a lot better. We had a fairly stiff sheet metal channel drive. I'm not sure if 1/8" or 5/32" would work out better. We haven't tried the 1/8" yet. For sure we would if we knew we were using the W-tread.
Unread 02-12-2014, 12:02
AdamHeard's Avatar
Lead Mentor
This is a good answer, anyone in here throwing out specific numbers is playing a dangerous game.
The last two years of sizing rules have really changed all this. Not many true "long" bots still exist, and it seems the square-bot is almost standard.
This along with more diversity in wheels being used, has greatly changed the game.
It used to be simple enough back in the days of 28x38 and almost everyone running kop or roughtop to say 3/16", but it isn't anymore.
You're doing people a disservice by stating a number as an absolute on here.
Unread 02-12-2014, 14:25
Joining the 900 Meme Team
FRC #0079
Just to illustrate this point: Black is the perimeter size, Blue is the actual wheelbase.
Edit: words cuz ether
Name:	Traditional 6wd Wheelbase.png
Unread 02-12-2014, 17:03
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
I think you'd find 3/16 to be too much at first, but it would improve with wear. 1/8 would be good at first, however, you'll probably need to replace wheels due to center wheel wear.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 02-12-2014, 17:05
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Based on what I've heard, 5/32 works well for a square drive with blue-nitrile wheels.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
