Go to Post So Love your robot, and it will love you. - Not2B [more]
View Poll Results: What type of plating does your team use?
Black Oxide 50 62.50%
Zinc Plated 8 10.00%
No standard, whatever is fine 22 27.50%
Voters: 80. You may not vote on this poll
Unread 02-12-2014, 19:49
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Fasteners: Black Oxide or Zinc Plated?
Depends on your goal: corrosion resistance or price? Black oxide is generally less costly, bright zinc is more corrosion resistant. Consider where you live: Desert or rainforest?
Unread 02-12-2014, 20:20
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Are black oxide from a local hardware store typically similar in strength to alloy steel black oxide from McMaster? I've always assumed they were, but I have heard otherwise, so I always wondered.
Unread 02-12-2014, 21:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Travis Schuh View Post
I am curious to see if teams in humid places like Florida have any corrosion issues, particularly once a robot has been retired for a few years. Robots in California are hardly the most rigorous use case.
I know that in Florida things will rust just about immediately if they aren't kept in a climate controlled building.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-12-2014, 21:10
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Our team standard is metric fasteners in black oxide, imperial in zinc. Helps with the inevitable sorting.
I'll be happy when everyone has moved over to metric. I'll be dead though
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 02-12-2014, 22:14
Or get covered with mildew or mold if non-metallic.
Unread 02-12-2014, 22:51
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Mcmaster has a wider selection and probably a wider quality range. But the equivalent grade would be the same. I mostly use grade 5 which is in the middle.
Commercial bolt threads are almost universally better than shop made. The commercial threads are rolled rather than cut & leaves compressive strain in the threads.
Unread 02-12-2014, 23:00
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Sorry, not super familiar with the manufacture of bolts, but could you explain what you mean by "compressive strain?"
On another note, in 2012, 2220 used grade 5 stainless 1/2-20 (if I remember correctly) bolts as axles on our robot. We made it the entire season without bending an axle significantly. Not saying it was a good idea, but it worked in our case.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 03-12-2014, 01:39
Cory's Avatar
AKA: Cory McBride
http://en.wikipedia.org/wiki/Shot_peening this has some decent non-jargon explanation of the principle.
Essentially introducing residual compressive stress on the surface through plastic deformation leads to prevention of crack propogation, increasing fatigue life.
With a rolled thread you are also increasing strength through cold working (strain hardening) the material, which improves both fatigue and tensile strength, but makes the material more brittle. This is also why form tapped holes are stronger than threaded holes produced with a cut tap.
2001-2004: Team 100
Unread 03-12-2014, 02:11
VioletElizabeth's Avatar
VioletElizabeth VioletElizabeth is offline
AKA: ECD
FRC #1868 (Space Cookies)
VioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really nice
To use the words I think in, my best guess as to what that means is you whack a thing so that each little bit of the surface wants to push itself apart/press against its own neighbor, which prevents cracks because cracks get pushed back together by this pushing.
Sorry if that was too silly, thinking in simple words helps me.
Unread 03-12-2014, 09:22
AKA: Nick Aarestad
Thank you very much for the explanations. That helped my understanding a lot.
tumblr | twitter
VEXU UMN (2015-??)
Unread 03-12-2014, 13:01
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Not a bad way of thinking of it. Shot peening parts does something similar & is also specified when fatigue cracking might be an issue. (not for threads so i am drifting off topic) Rolling the thread also gives is a better surface finish than a cutting tool that leaves little micro cracks the form stress risers.
Unread 03-12-2014, 13:10
I just like black. It looks better on aluminum so you can always tell when something has fallen out.
Unread 03-12-2014, 13:41
Joining the 900 Meme Team
FRC #0079
Not usually during season, but I know 79 had some issues with cylinders rusting after a few years. The 07 bot in particular has a lot of rust on the cylinders.
Unread 03-12-2014, 15:58
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
The only rust I've seen of any consequences are on robots improperly stored. So unless you're planning to store them in an outdoor location or unsealed space, you should be ok with whatever.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 03-12-2014, 16:01
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Our workshop has humidity problems when the AC is off in the summer. All of our black oxide screws have surface rust on them.
2016: FRC 865 Mentor
