#226
Re: blog; Motor Controller Options for 2015
Just got word from vex saying that the new talons will not be available to order till late December.
#227
Can't speak for the Talon SRX, but I just played around with error recovery for the PCM. I pulled PCM power towards the beginning of the flash, towards the middle of the flash, and towards the end of the flash. In all cases I was able to recover.
#228
Sweet. That was one of my big concerns when flashing CAN Jags.
#229
Do the new talons communicate with CAN over the PWM cable? If so that's awesome.
#230
The new Talon will auto detect whether you are connect to a can bus or a pwm source. On FRC you only need two wires for PWMs (signal and ground) to an FRC legal motor controller because all FRC motor controllors ignore the center power pin (these are only used for servos) You can wire the 2 CAN wires on the Talon SRX to PWM signal and ground and it will auto detect PWM. CAN_H = PWM Signal CAN_L = PWM Ground The Victor SP (which has a 3-pin PWM) can only be used in PWM mode, no CAN available Hope this helps, Kevin |
#231
R55 G Last edited by Ether : 16-01-2015 at 11:09. |
#233
I think it's fair to point out that we are nearing the end of build season, and presumably most teams have got their big orders in...
Vex is still in stock. WCProducts is still in stock. Andymark is still in stock. RobotSpace is still in stock (For Victors, Talons are out. Based on everyone else having stock, I'm sure they will get replenished soon.) So................. They handled it awesome in my opinion. |
