Go to Post You know, if I was John V-Neun I would get a copyright on my name! - Jay H 237 [more]
Unread 03-12-2014, 18:38
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Using Lejos to program an FTC style robot
My mentor has tasked me along with a few other students to build an FTC style robot (tetrix build kit with an NXT brain) to show off to students in the area for recruiting. We no longer have an FTC team but we think its something simple that will spark people's interests in robotics without having to lug our FRC bot around. The only problem is that we no longer have an active RobotC license and our mentor doesn't think its worth it to purchase one and wants us to think outside of the box and challenge ourselves. I have decided to use the Lejos NXJ library for Java because it seems to suit our purposes and I think it will be good practice for myself and some newer members for this upcoming season. It seems simple enough to write an autonomous program but I was wondering if anybody could give me some help with writing a program for driver control using a joystick controller (Logitech F310 Gamepad) through bluetooth. Any help would be greatly appreciated even if its just about using Lejos in general and other helpful tips.
TL;DR: I need help to write a Lejos NXJ program using a joystick controller through bluetooth.
Unread 03-12-2014, 19:41
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: Using Lejos to program an FTC style robot
I did some Bluetooth control with LeJos and Lego robots I will try and dig up my code for you.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 03-12-2014, 23:18
AKA: Spencer Lanman
I know that there's a lot of sample material you can essentially cut and paste on with the Bluetooth connections (as it can be somewhat code intensive but fairly redundant). For the joystick you could use a library like Jinput.
Here's some simple code I rooted up from like 2 years ago. This was just an experiment to see how the Bluetooth worked. It allowed me to drive my robot with the WASD keys.
There is both computer (client) and robot (server) side code here:
ShooterClient.java
package control.client.shooterBot;
import java.awt.Container;
import java.awt.FlowLayout;
import java.awt.event.KeyEvent;
import java.awt.event.KeyListener;
import java.io.DataOutputStream;
import javax.swing.JFrame;
import javax.swing.JTextArea;
import javax.swing.JTextField;
import javax.swing.JTextPane;
import lejos.pc.comm.NXTConnector;
public class ShooterClient extends JFrame implements KeyListener {
	private static final long serialVersionUID = -1955110733792225783L;
	//COMMANDS
	public static final int
		TURN_LEFT = 1,
		TURN_RIGHT = 2,
		FWD = 3,
		BWD = 4,
		SHOOT = 5,
		STOP = 6,
		STOPSHOOT = 7,
		TERMINATE = 99;
	//KEYBOARD INPUTS
		FORWARD = 87, //W
		BACKWARD = 83, //S
		LEFT = 65, //A
		RIGHT = 68, //D
		FIRE = 32, //SPACEBAR
		QUIT = 81; //Q
	boolean steerReleased = true;
	boolean driveReleased = true;
	NXTConnector bt;
	DataOutputStream out;
	JTextField text = new JTextField(15);
	public ShooterClient (String title) {
		super(title);
		this.setDefaultCloseOperation(EXIT_ON_CLOSE);
		this.setSize(500, 300);
		text.setEnabled(false);
		Container pane = this.getContentPane();
		pane.setLayout(new FlowLayout());
		pane.add(text);
		this.setVisible(true);
		bt = new NXTConnector();
		boolean connected = bt.connectTo("btspp://");
		if (!connected) {
			System.err.println("Failed to connect to NXT!");
			text.setText("Failed to connect to NXT!");
		} else {
			out = new DataOutputStream(bt.getOutputStream());
			this.addKeyListener(this);
	public static void main(String[] args) {
		new ShooterClient("Enter Commands");
	public void keyTyped(KeyEvent e) {
	public void keyPressed(KeyEvent e) {
		switch (e.getKeyCode()) {
			case FORWARD:
				if (driveReleased) {
					giveCmd(FWD);
					text.setText("Forward");
					driveReleased= false;
				break;
			case BACKWARD:
					giveCmd(BWD);
					text.setText("Backward");
				break;
			case LEFT:
				if (steerReleased) {
					giveCmd(TURN_LEFT);
					text.setText("Left");
					steerReleased= false;
				break;
			case RIGHT:
					giveCmd(TURN_RIGHT);
					text.setText("Right");
				break;
			case FIRE:
				giveCmd(SHOOT);
				text.setText("Shoot");
				break;
	public void keyReleased(KeyEvent e) {
			case FORWARD:
			case BACKWARD:
				giveCmd(STOP);
				driveReleased= true;
				text.setText("Stopped");
				break;
			case LEFT:
			case RIGHT:
				giveCmd(STOP);
				steerReleased= true;
				break;
			case FIRE:
				giveCmd(STOPSHOOT);
				text.setText("Stopped Shooting");
				break;
			case QUIT:
				giveCmd(TERMINATE);
				text.setText("Quitting");
				System.exit(1);
				break;
	public void giveCmd(int cmd) {
		try {
			out.writeInt(cmd);
			out.flush();
		} catch (Exception e) {
			e.printStackTrace();
ShooterServer.java
package control.server.shooterBot;
import java.io.DataInputStream;
import lejos.nxt.Motor;
import lejos.nxt.Sound;
import lejos.nxt.comm.Bluetooth;
import lejos.nxt.comm.NXTConnection;
import lejos.robotics.navigation.DifferentialPilot;
public class ShooterServer {
	//COMMANDS
		LEFT = 1,
		RIGHT = 2,
		FWD = 3,
		BWD = 4,
		SHOOT = 5,
		STOP = 6,
		STOPSHOOT = 7,
		QUIT = 99;
	public static boolean
		isLeft = false,
		isRight = false,
		isFwd = false,
		isBwd = false;
	private static double radius = 0;
	private static double distance = 0;
	public static DifferentialPilot robot;
	public static WaitForThread WFT;
		Motor.A.setSpeed(900);
		robot = new DifferentialPilot(3.8, 13.1, Motor.C, Motor.B, false);
		WFT = new WaitForThread();
		WFT.start();
		while(true) {
			System.out.println("Waiting for Connection...");
			NXTConnection bt = Bluetooth.waitForConnection();
			DataInputStream stream = bt.openDataInputStream();
			System.out.println("Connected");
			Sound.beepSequenceUp();
			int input = 0;
			do {
				try {
					input = stream.readInt();
					System.out.println("Command: "+input);
				giveCmd(input);
			} while(input != QUIT);
			try {
				stream.close();
				Thread.sleep(100);
				bt.close();
				Sound.beepSequence();
	private static void giveCmd(int cmd) {
		switch (cmd) {
			case LEFT:
				robot.rotateLeft();
				break;
			case RIGHT:
				robot.rotateRight();
				break;
			case FWD:
				robot.forward();
				break;
			case BWD:
				robot.backward();
				break;
			case SHOOT:
				Motor.A.forward();
				break;
			case STOP:
				robot.stop();
				break;
			case STOPSHOOT:
				Motor.A.stop();
				break;
WaitForThread.java
import lejos.nxt.SensorPort;
import lejos.nxt.TouchSensor;
import lejos.nxt.UltrasonicSensor;
public class WaitForThread extends Thread {
	public TouchSensor TS;
	public UltrasonicSensor US;
	public WaitForThread() {
		TS = new TouchSensor(SensorPort.S2);
		US = new UltrasonicSensor(SensorPort.S4);
	public void run() {
		try {
			sleep(500);
		} catch (InterruptedException e) {
		while (true) {
			if (TS.isPressed()) break;
		System.exit(1);
Shooter Operator
Catapult Operator
Chainsaw Operator
Last edited by Team3266Spencer : 03-12-2014 at 23:19. Reason: Just realized you are using NXT so my comment about EV3 is irrelevant
Unread 04-12-2014, 17:53
Jalerre's Avatar
FRC #4965 (FIRE)
Thanks. This is really helpful. If anyone has any experience with JInput, tips for that would be helpful too. I considered using it but I didn't know if there was any better option. I don't have much experience using it but I think I can figure it out.
Unread 04-12-2014, 19:34
AKA: Spencer Lanman
I'm glad this is helpful! I'm really glad I found these files. They were in some obscure location on my computer. XD
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 04-12-2014, 22:50
DonRotolo's Avatar
Back to humble
FRC #0832
I suppose I could just Google it, but what is a Lejo?
Unread 04-12-2014, 22:56
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Java for the LEGO Mindstorms controllers.
Unread 06-12-2014, 18:12
AKA: Spencer Lanman
leJOS stands for Lego Java Operating System
Shooter Operator
Catapult Operator
Chainsaw Operator
