Go to Post Don't put sprockets in an empty pizza box and then throw it into the garbage. Something we learned from experience. - Herodotus [more]
Unread 04-12-2014, 09:43
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: RoboRIO in stock at AM
Originally Posted by AllenGregoryIV View Post
Everything I have heard says they won't be releasing code until kickoff. I've also heard you may be able to flash the myRIO image on to them but you won't have WPILib or any of the other FRC items, haven't tried it myself but I might if I find time this weekend (our roboRIO comes in tomorrow).
You won't be able to write a myRIO image to the device, but there might be enough roboRIO support in last year's LabVIEW (LabVIEW 2013) to get just the operating system installed. I'll try to look into this today and report back whether it's safe or not.
Unread 04-12-2014, 14:57
I loaded up a machine with LabVIEW 2013 on it and was able to find the roboRIO in NI MAX. You can use NI MAX to install LabVIEW RT 2013 to the target, which also installs the Linux OS. From there you can enable the sshd in MAX as well and you should have access to log into the roboRIO and play with the OS. Naturally this is the OS from over a year ago, not the newer version that will be included in the FRC images. There are a number of differences, but there are more similarities, so you can gain some familiarity with the layout of the file system. This is only if you want to tinker with the system before kick-off. You won't have FPGA support, so you can't talk to any I/O. When you get the image on kick-off day, you will be formatting the root FS, so don't expect to keep any changes you may make to this older version of the OS.
Bottom line, if you really want to play with Linux on the target, do this. If you expect to "use" the device to "do something", this won't help you.
Unread 15-12-2014, 13:13
Now that the FRC 2015 base software is available and can be run in eval mode until kick-off, this situation improves. You can now play around with the version of the OS for the roboRIO that will be used for competition in 2015. Same instructions above apply, but the LabVIEW version is 2014.
https://decibel.ni.com/content/docs/DOC-34731
Unread 15-12-2014, 17:18
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Good news. We've been limited to physical testing so far.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-12-2014, 22:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
HAWHAWHAWHAWHAW!
Unread 15-12-2014, 23:19
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
My wife found a good place for the roboRIO.
Unread 15-12-2014, 23:49
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Well milk warmer is better than pizza oven.
But then again, it's a milk warmer when it's not even plugged in ?!?
Software Mentor
3853 Pridetronics[
Unread 15-12-2014, 23:50
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
But does it blend?
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 16-12-2014, 09:28
crake crake is offline
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Originally Posted by Kevin Selavko View Post
But does it blend?
Yes. Yes it will. However this will void your warranty.
Unread 16-12-2014, 12:42
virtuald's Avatar
RobotPy Guy
I can confirm that these instructions work. I can also confirm that the roboRIO is still a useless brick after following these instructions, even with access to the WPILib 2015 source code.
