Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 04-12-2014, 14:33
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
pic: KING TeC Drivetrain Prototype
Unread 04-12-2014, 14:34
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: KING TeC Drivetrain Prototype
What's your plan for mounting bumpers?
Unread 04-12-2014, 17:32
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
This looks great!!! I'm also curious about bumper placement though.
Unread 04-12-2014, 19:38
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Planning on making a hexagonal/octagonal chassis? The center output shaft looks like its meant to have a wide wheel on it.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 04-12-2014, 19:44
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
How did you curve those improvised gearbox covers? Did you heat them or just bend them?
Unread 04-12-2014, 19:47
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
The WCP transmission comes with an extra long shaft. It probably just wasn't cut down, I don't think the hole for the retaining bolt goes that deep into the shaft.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 04-12-2014, 19:52
saikiranra's Avatar
UCI
Ahhh, thanks. That makes more sense.
Unread 04-12-2014, 20:46
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
We made pretty much identical gearbox covers last year. Polycarbonate that thin bends very very easily.
Unread 04-12-2014, 23:56
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
I also have concerns about meeting bumper rules:
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside corner
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER.
You could possibly mount a plate on your corners to meet these rules...
Unread 05-12-2014, 00:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I'm sure they have a plan for the bumpers (besides, per the rules they can't use this for the competition this year, merely as practice/training/experimenting)... KING TeC is a rather experienced team here in MN, and they know if they show up in Duluth with bumper problems I'll roast them over the coals and eat their robot for breakfast
2016: Lake Superior WFFA
Unread 05-12-2014, 14:10
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
In regards to bumpers: We have no plans to mount bumpers on this prototype. We have, however, thought of ways we would mount them to the chassis. I stole this pic from a recent post (credit to Team 2451.) We would do something similar to what is depicted, using spring loaded latches to attach the bumpers. (Assuming the 2015 game allows for such a design.)
We will try our best to show up without bumper problems, we dislike both third degree burns and digested robots
Unread 05-12-2014, 14:16
Please note that that picture does have an issue in the corners - you need a frame member that is actually in the corner, otherwise your frame perimeter would be wrapping around the front and back wheels, which isn't allowed. Structural standoffs between the wheels isn't the issue, it's what to do in the corners!
Unread 05-12-2014, 15:23
llamadon's Avatar
Gold pants swag
AKA: Quinn
I think I get it. I drew out what I interpreted to be sure. Is my sketch accurate as to what you are saying?
Unread 05-12-2014, 15:27
Andrew Lawrence
Posts: n/a
[Image]
Courtesy of Team 254's website - you don't need to exactly have it set up that way.
