Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Thread Tools Rating: Thread Rating: 83 votes, 5.00 average. Display Modes
Unread 11-10-2014, 11:10
OPR Programming Challenge
Given the dataset Michael Hill posted here, calculate OPR, DPR, and CCWM; and create a report sorted by team number.
The goal is to see who can go from raw input data to finished output report the fastest.
@ Michael Hill: please refrain since you and I have discussed this.
Unread 11-10-2014, 11:30
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: OPR Programming Challenge
by "fastest" do you mean the first response or fastest operational efficiency?
Unread 11-10-2014, 19:14
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
I believe operational efficiency is the goal; however, Ether can speak for himself on that...
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 11-10-2014, 19:44
Michael Hill's Avatar
*Actively Refraining* ...if that's possible
Unread 05-12-2014, 01:40
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
I'm about 2 months late, but I think I have generated an accurate report. Some of the OPR and CCWM values are identical to the 1114/2834 databases, while others are a few values off. I don't know whether this is an input error, matrix inversion error, or general code bug.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 05-12-2014, 09:34
Thanks for posting. Maybe this will revive interest in the thread.
Did you time how long it took the computer to go from raw input data to finished output report ? That's the challenge.
http://www.chiefdelphi.com/forums/sh...29&postcount=7
Unread 05-12-2014, 20:59
saikiranra's Avatar
UCI
Oops, sorry for not posting it. Over 10 runs, it averaged 0.823266 seconds to generate the output.
As for the matrix inversion, I didn't realize that the Cholesky solving library I used didn't find the inverse, rather it found Cholesky factorization of the matrix.
Unread 05-12-2014, 21:23
That's pretty good.
The challenge includes the total time to do all these steps*:
  1. - read Michael's 8-column fixed-width data file
  2. - convert that data into a set of linear equations
  3. - compute the solution vectors OPR, DPR, & CCWM
  4. - sort the solution vector elements in ascending order by team number
  5. - write the output report to a disk file.
Please report the times for each of the above steps.
What hardware did you run this on? What software did you use?
*if you used different steps, please explain and provide timings
Unread 05-12-2014, 23:56
saikiranra's Avatar
UCI
Out of 50 runs, these are the average times to:
1. Read from file to create data structures: 0.3636 seconds
2. Make sorted team lists and Bs in Ax=B: 0.0019 seconds
3. Make matrix A in Ax=B: 0.0675 seconds
4. Create Cholesky factorization and find OPR and CCWM values (DPR = OPR - CCWM): 0.2793 seconds
5. Write to file: 0.0242 seconds
(Record these times: 0.0128 seconds)
Total: 0.7494 seconds
I wrote this in Python using the numpy and scipy libraries to manipulate matrices. The software is running on a Windows 8 machine with an Intel i7-4700MQ running at 2.4 GHz, with 12 GB of RAM.
Unread 06-12-2014, 12:21
Nice work.
For those of you reading along, the timing above is for a dataset containing 2696 teams, 8921 matches, 17842 alliance scores.
@ Michael Hill: feel free to jump in here now if you want :-)
Unread 06-12-2014, 16:35
Nice work.
Fair enough. It's been a while since I've messed around with this, but I dug up my MATLAB script I originally did this with. I got it down to 0.518726 seconds (average over 10 runs.)
There are some optimizations that are done with this. For example, using sparse matrices lets MATLAB do a much quicker job of left divides (which is not the same as inverting the matrix). MATLAB is actually fairly smart and decides which form of factorization to use based on the data that's inputted, so it (generally) will choose the fastest method. Sparse is very fast.
tic
alldata = dlmread('C:\Users\Michael Hill\Documents\Projects\OPR\scores.dat');
teams = [alldata(:,1:3); alldata(:,4:6)];
reddiff = [alldata(:,7)-alldata(:,8)];
bluediff = [alldata(:,8)-alldata(:,7)];
scores = [alldata(:,7); alldata(:,8)];
diffscores = [reddiff; bluediff];
a = size(teams);
A = zeros(max(max(teams)));
B = zeros(max(max(teams)),2);
for i = 1:a(1)
    A(teams(i,1),teams(i,1)) = A(teams(i,1),teams(i,1)) + 1;
    A(teams(i,1),teams(i,2)) = A(teams(i,1),teams(i,2)) + 1;
    A(teams(i,1),teams(i,3)) = A(teams(i,1),teams(i,3)) + 1;
    A(teams(i,2),teams(i,1)) = A(teams(i,2),teams(i,1)) + 1;
    A(teams(i,2),teams(i,2)) = A(teams(i,2),teams(i,2)) + 1;
    A(teams(i,2),teams(i,3)) = A(teams(i,2),teams(i,3)) + 1;
    A(teams(i,3),teams(i,1)) = A(teams(i,3),teams(i,1)) + 1;
    A(teams(i,3),teams(i,2)) = A(teams(i,3),teams(i,2)) + 1;
    A(teams(i,3),teams(i,3)) = A(teams(i,3),teams(i,3)) + 1;
    B(teams(i,1),1) = B(teams(i,1),1) + scores(i);
    B(teams(i,2),1) = B(teams(i,2),1) + scores(i);
    B(teams(i,3),1) = B(teams(i,3),1) + scores(i);
    B(teams(i,1),2) = B(teams(i,1),2) + diffscores(i);
    B(teams(i,2),2) = B(teams(i,2),2) + diffscores(i);
    B(teams(i,3),2) = B(teams(i,3),2) + diffscores(i);
end
%gpuA = gpuArray(A);
%gpuB = gpuArray(B);
A = sparse(A);
B = sparse(B);
A(~any(A,2), :) = [];
A(:, ~any(A,1)) = [];
B(~any(B,2), :) = [];
X = A\B(:,1);
Y = A\B(:,2);
D = X-Y;
tdupe = sort([teams(:,1);teams(:,2);teams(:,3)]);
[junk, index] = unique(tdupe,'first');
teamList = tdupe(sort(index));
numTeams = size(teamList);
out = zeros(numTeams(1),4);
for i = 1:size(teamList)
    out(i,1) = teamList(i);
    out(i,2) = gather(X(i));
    out(i,3) = gather(Y(i));
    out(i,4) = gather(D(i));
end
% expectedRed = zeros(a(1)/2,1);
% expectedBlue = zeros(a(1)/2,1);
% for i=1:a(1)/2
%     index1 = find(out(:,1)==alldata(i,1));
%     index2 = find(out(:,1)==alldata(i,2));
%     index3 = find(out(:,1)==alldata(i,3));
%     index4 = find(out(:,1)==alldata(i,4));
%     index5 = find(out(:,1)==alldata(i,5));
%     index6 = find(out(:,1)==alldata(i,6));
%     opr1 = out(index1,2);
%     opr2 = out(index2,2);
%     opr3 = out(index3,2);
%     opr4 = out(index4,2);
%     opr5 = out(index5,2);
%     opr6 = out(index6,2);
%     expectedRed(i) = opr1+opr2+opr3;
%     expectedBlue(i) = opr4+opr5+opr6;
% end
% diffExpRed = expectedRed - alldata(:,7);
% diffExpBlue = expectedBlue - alldata(:,8);
% diffExp = [diffExpBlue; diffExpRed];
% C = zeros(gather(max(max(teams))));
% for i = 1:a(1)
%     C(teams(i,1)) = C(teams(i,1)) + diffExp(i);
%     C(teams(i,2)) = C(teams(i,2)) + diffExp(i);
%     C(teams(i,3)) = C(teams(i,3)) + diffExp(i);
% end
% gpuC = gpuArray(C);
% gpuC(~any(gpuC,2), :) = [];
% Z = gpuA\gpuC(:,1);
% for i = 1:size(teamList)
%     out(i,5) = gather(Z(i));
% end
disp(out);
toc
There are some remnants in the comments of me messing with gpuArrays on MATLAB, and I'm too lazy to get rid of them. I have a Quadro K1100M Graphics card in my laptop, so I was messing around with using CUDA cores. It turns out that MATLAB has not implemented sparse matrices with CUDA processing, so they have to be full matrices, which actually slows it down (fairly significantly) over using sparse matrices with calculation on the CPU. For the record, my CPU is an Intel i7-4702HQ @ 2.2 GHz with 16 GB of RAM (My Computer is a Dell Precision M3800).
EDIT: I actually just realized there was some code that slows it down in there. the "gather"s in developing the "out" matrix are more remnants of GPU computing that I didn't take out. They are used for getting the variables out of GPU memory to my RAM. After removing them, It took total computation time to about 0.48 seconds.
Unread 06-12-2014, 16:44
Here's another optimization you can try. Replace this code:
X = A\B(:,1);
Y = A\B(:,2);
... with this:
XY = A\B
... then you'll have only one left-divide, and the XY vector will be a 2-column vector containing X and Y.
Unread 06-12-2014, 19:13
X = A\B(:,1);
Y = A\B(:,2);
... with this:
XY = A\B
Made it a bit faster (0.02 seconds). I expected it to be a lot more, but surprisingly, reading the file into MATLAB is the longest operation at 0.31 seconds (That's reading in the file and creating my A and B matrices). It surprises me it takes that long with a the SSD I have.
Unread 09-12-2014, 11:40
Could I talk you into putting separate tic/toc statements around
and
for i = 1:a(1)
end
Unread 11-12-2014, 17:15
and
for i = 1:a(1)
end
Sorry it's taken so long, I've been somewhat busy the last few days at home.
The first one is ~0.025 sec and the second (around the for loop) is ~0.235 sec
