Go to Post Unfortunately, not everyone is Andy Baker. If everyone had this mindset, there would be far fewer problems. - Kevin Kolodziej [more]
Unread 06-12-2014, 21:57
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Arduino Motor Controller
This definitely works. We have an entire product based on the idea of running robots with Arduinos.
You the servo library for basic functions.
Or...load the RobotOpen library...this will also give you the ability to control the speed controller with a gamepad using our open-source driver station.
The library designed for the RobotOpen Control Shield should work fine on a standard Arduino. You'll have to map some of the pins differently, if not using our shield, but it can be done.
Send me a PM if you have any specific questions.
We did this a while back and if there is one thing I recommend is trying to emulate some of the safety features built into the typical FRC control system.
The RobotOpen library adds these types of safety features and gives you a reliable method for enable/disable.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 06-12-2014, 23:22
BN1557's Avatar
BN1557 BN1557 is offline
Team Captain/Drive Coach/Mechanical
FRC #1557 (12 Volt Bolt)
BN1557 is an unknown quantity at this point
Thanks for all the help. I appreciate it!
