Go to Post But FIRST isn't FRC anymore. We need to make way for FTC and FLL. - Tetraman [more]
Unread 07-12-2014, 03:22
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 3 CIM WCD Ball Shifter Second Edition
Originally Posted by Bryce2471 View Post
Out of curiosity:
Why is doing this useful?
Why couldn't you do this with the gearbox design that I posted?
We like the ability to do that so we can add CIMs in later/makes wiring a little easier without CIMs in the way. Also much much lighter without the CIMs in so its easier to handle etc..
The reason why I'm not a huge fan of using all bolts connected to CIMs is during assembly you either:
a) Have to assemble with CIMs to hold the gearbox together or
b) Put it together and put nuts in the back, then when putting in CIMs having to take each nut off.
Nothing crazy revolutionary but could make your life easier.
R.C.
MadTown Robotics Team 1323
Unread 07-12-2014, 03:33
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
That makes sense. I agree that it would be a slight inconvenience. Although I like the idea of using the CIMs as standoff nuts because most of the forces on the back plate come from the CIM mounts, and because it lightens things.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 07-12-2014, 04:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
It would be a pretty big inconvenience IMO. Gearbox assembly is already hard enough, as I learned last week.
It doesn't hurt that much to add different mounting holes for the cims. Plus, then you can use a system like what 192 used to tension gearbox belts this year to allow for different pinions to be mounted.
We tried assembling WCP gearboxes. It took us around five hours to assemble two gearboxes due to some unforseen issues. It's a great gearbox design for teams with little manufacturing resources. But some parts, like the sping washers, are really annoying to work with if you have enough machining resources to make it fit properly.
Also, R.C, if you are reading this, there was a slight error in the instuction manual. A 1/32" spacer is explicitly stated to be a 1/16" spacer in the instuctions. Not sure if that's our problem or something wrong with the manual.
Unread 07-12-2014, 04:35
R.C.'s Avatar
Assembly should take around 20-30 minutes a gearbox, we used 4 3 CIM WCD gearboxes this year.
I'm not a fan of the spring wave either, it'll be replaced out to a solid washer in the future here soon...
I'll take a look and your more than welcome to email me here. Please email me what gearbox you were using and which manual etc.. That way we can take care of the typo.
Thanks
R.C.
Unread 07-12-2014, 04:40
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Thanks
In the future I'm sure we could do it faster. First time is the hardest, I think.
I will shoot you an email just as soon as my team has its next meeting.
Unread 08-12-2014, 16:19
Chris is me's Avatar
AKA: Pinecone
As others have mentioned, bearing bore gears and shoulder bolts will save you some weight and bearings. You can even bore out a smaller gear to accept smaller OD bearings.
It is non-trivial to ensure that the idler gears mesh with both pinions and the large cluster gear at the same time. While the outer CIMs can freely rotate, the middle CIM meshing with both idler gears will lock their orientation relative to each other, and if this combined orientation does not line up with the large cluster gear, the gearbox will not work. It is a lot less elegant to do it this way, but two motors on one idler and one motor on the other idler would be a bit safer and more tolerant of misalignment.
about the above - sorry, misunderstood gearbox initially. I see the gears on the right idler gear now, for some reason I thought another shaft was buried in there. In this case, I would just like to comment on the use of a 12T CIM pinion as an idler - this may not work well particularly if the pinion is aluminum. A lot of force going through a tiny gear. That's not to say it's impossible or not doable, just be careful.
Personally I like this design a lot better than the previous revision. The extra gear is a thing, yes, but the design is more symmetrical, compact, and in many ways simpler. Just seems more elegant to me.
